Hi Jason !!!
Hi ,
I am not old to SE automation...for help i want some programming material to be used with vb.net...n if there are any sample codes i will be so thankful
Thanks n regards
Prasad
Posted by: Prasad Pawar
Post date: 7/12/2007 9:11:52 PM
RE: Hi Jason !!!
Prasad,
Look at the "Code Repository" link on the menu. I just added that page and put my 2005 - 2007 Solid Edge developers conference material in there for download. You should find plent of examples there.
Posted by: Jason Newell
Post date: 7/14/2007 9:03:46 AM
RE: Hi Jason !!!
I looled in that link...but i ahve not found any for download..there is no option to download it
Post date: 7/16/2007 2:08:02 AM
RE: Hi Jason !!!
It was a security setup problem. I think it's fixed now.
Post date: 7/16/2007 3:28:14 AM
