Hide refPlanes, hide sketches, fit on window, Isometric View
Hello all.
I want write code, which hide refPlanes, hide sketches, fit on window and isometric view before save part document.
At this time I know, what hide refPlanes and fit on window:
        objDoc.ToggleRefPlanesDisplay (False)
        Set wd = objApp.ActiveWindow
        wd.View.Fit
But how hide sketches and do isometric view (hotkey Ctrl+I) I don't know.
Please help me!
Posted by: Anton Bykov
Post date: 6/1/2010 6:49:30 PM
3 REPLIES 3
RE: Hide refPlanes, hide sketches, fit on window, Isometric View
Frantic,
This will work for parts, you have to rewrite it for other environments.
Good luck!
____________________________________________________________________________
Public Sub HideSketchesAndPutInIsoView()
On Error Resume Next
Dim objApp As SolidEdgeFramework.Application
Dim objDoc As SolidEdgePart.PartDocument
Dim objSketches As SolidEdgePart.Sketchs
Dim objSketch As SolidEdgePart.Sketch
Dim objProfiles As SolidEdgePart.Profiles
Dim objProfile As SolidEdgePart.Profile
'Get SE
    Set objApp = GetObject(, "SolidEdge.Application")
    If Err Then
        Err.Clear
        Set objApp = CreateObject("SolidEdge.Application")
    End If
    objApp.Visible = True
'Set
    Set objDoc = objApp.ActiveDocument
    Set objSketches = objDoc.Sketches
'Loop through all the sketches and profiles (do something similar in the assembly environment,
'sketch are called layouts there. Use the Spy to check it out.
    For Each objSketch In objSketches
        Set objProfiles = objSketch.Profiles
        For Each objProfile In objProfiles
            objProfile.Visible = False
        Next
    Next
'Isoview (make sure to have made a reference to the SolidEdge Constants Type Library. Use the Event Spy
'to get the command Id's
    'Call objApp.StartCommand (AssemblyCommandConstants.AssemblyViewISOView) 'Assembly
    Call objApp.StartCommand(partCommandConstants.partViewISOView) 'Part
'Release objects
    Set objApp = Nothing
    Set objDoc = Nothing
    Set objSketches = Nothing
    Set objSketch = Nothing
End Sub
Posted by: Wouter Sloof
Post date: 6/1/2010 7:54:04 PM
ErWo, thank you.
It worked!!!
Post date: 6/1/2010 8:08:57 PM
Re: RE: Hide refPlanes, hide sketches, fit on window, Isometric View
Can you share with me this macro, i put this code to VS, but i did something wrong,  and it doesn`t work. thanks
