Hole Data
Innovator
Innovator
Hi all,
I tried to display the hole type with C#.
Why the three type of holes "Simple", "Threaded" and "Tapered" have the same type hole(igregularhole)?
application = (SolidEdgeFramework.Application)Marshal.GetActiveObject("SolidEdge.Application");
partDocument = application.ActiveDocument as SolidEdgePart.PartDocument;
holes = partDocument.HoleDataCollection;
if (partDocument != null)
{for (int i = 1; i <= holes.Count; i++)
holedata = holes.Item(i);
MessageBox.Show("Hole Name : " + holedata.DisplayName+ "\n Type Hole : " + holedata.HoleType);}
Thanks.
Best regards,
1 REPLY
Re: Hole Data
Hi Sonny_Ria,
I rather would traverse the Holes collection and for each Hole object would use its HoleData object to inspect its HoleType property. May be this solves your observations.
Kind regards,
Wolfgang Kunert - www.wksyspro.de
