How To Use: Convert To SheetMetal With VB.NET2005
Hi all,
I am wrote a code that find the largest face in the active sheet metal
document body.
there is a ConvToSMs.add(RefFace,[],[],[],[])    function that need to get
RefFace and some optional args.
When I enter the largestFace  that I found I get Error Msg (atached to this
mail)
how should i define RefFace?
the code is:
Sub
SEconvertToSM(ByVal SMmodel As SolidEdgePart.Model)Dim SEbody As SolidEdgeGeometry.BodyDim SEfaces As SolidEdgeGeometry.FacesDim SEface As SolidEdgeGeometry.FaceDim SETopface As SolidEdgeGeometry.Face'Dim refFace As SolidEdgeFramework.Reference
SETopface = Nothing
SEbody = SMmodel.Body
SEfaces = SEbody.CreateCollection(SolidEdgeGeometry.TopologyCollectionTypeConstants.seFaceCollection)
SEfaces = SEbody.Faces(SolidEdgeGeometry.FeatureTopologyQueryTypeConstants.igQueryPlane)
 ForEach SEface In SEfacesIf SETopface IsNothingThen
SETopface = SEface
 EndIf
 If SEface.Area > SETopface.Area Then
SETopface = SEface
 EndIf
 Next
 SMmodel.ConvToSMs.Add(SETopface))
SEbody = Nothing
SEfaces = Nothing
SEface = Nothing
SETopface = Nothing
 EndSub
 Amir
Amir
Posted by: amir zeltzer
Post date: 11/29/2007 8:01:17 AM
