How can I know the object type of an smartFrame2d embed or linked object
Hello
I have to do some updating on smartFrame2d embeded objects but I am not able to know what type of information is embeded in the object (excel, word, image, txt file).
How can I get the type of the object embed (something like the "show interface name" in solid edge spy will be fine or is there any other way to know the object type)
Thanks in advance
Posted by: Xabi Bikuna Losada
Post date: 3/25/2011 3:33:10 AM
RE: How can I know the object type of an smartFrame2d embed or linked object
Did you try the ObjectType property, which returns a string of your object's type?
Posted by: Martin Bernhard
Post date: 3/25/2011 5:00:29 AM
Objecttype parameters is empty so it can't be used
Anyway I found some jasonnewell.net code in this page
http://www.ureader.com/msg/14312747.aspx
I thnik this is part of the used in solidedge spy to get the com structure. I wanted it in VB.NET so I translated it and it works great so i can do what I was thinking.....
Althoug I found it in another page, thanks Jason
How to use ite
      objSheet = objDraft.ActiveSheet
      objSFrames2D = objSheet.SmartFrames2d
      For Each objSFrame2D In objSFrames2D
        Dim o As Object = objSFrame2D.Object
        If (Marshal.IsComObject(o)) Then
          Dim comObject1 As ComObject = Nothing
          Dim comObject As ComObject = New ComObject(o)
          Dim propertyNames As String() = comObject.GetPropertyNames()
          Dim prop As Object = Nothing
          Dim propertyName As String
          For Each propertyName In propertyNames
            prop = comObject.WrappedComObject.GetType().InvokeMember(propertyName, _
            System.Reflection.BindingFlags.GetProperty, Nothing, _
            comObject.WrappedComObject, Nothing)
            If (prop IsNot Nothing AndAlso Marshal.IsComObject(prop)) Then
              comObject1 = New ComObject(prop)
            End If
          Next
        End If
If someone whats the code here it is (3 Vb.NET files):
ComObject.vb
Imports System
Imports System.Collections.Generic
Imports System.Runtime.InteropServices
Imports System.Runtime.InteropServices.ComTypes
Imports System.Text
Public Class ComObject : Implements IDisposable
  Private _object As Object
  Private _dispatch As IDispatch
  Private _pTypeAttr As IntPtr = IntPtr.Zero
  Private _typeInfo As System.Runtime.InteropServices.ComTypes.ITypeInfo
  Private _typeName As String
  Private _typeDescription As String
  Private _typeHelpFile As String
  Private _typeHelpContext As Integer
  Private _comTypeLibrary As ComTypeLibrary
  Public Sub New(ByVal comObject As Object)
    Dim ppTLB As System.Runtime.InteropServices.ComTypes.ITypeLib = Nothing
    Dim pIndex As Integer = 0
    _dispatch = CType(comObject, IDispatch)
    If (_dispatch IsNot Nothing) Then
      _object = comObject
      _typeInfo = _dispatch.GetTypeInfo(0, 0)
      _typeInfo.GetTypeAttr(_pTypeAttr)
      _typeInfo.GetDocumentation(-1, _typeName, _typeDescription, _typeHelpContext, _typeHelpFile)
      _typeInfo.GetContainingTypeLib(ppTLB, pIndex)
      _comTypeLibrary = New ComTypeLibrary(ppTLB)
    Else
      Throw New InvalidComObjectException()
    End If
  End Sub
  Protected Overrides Sub Finalize()
    Dispose()
  End Sub
  Public Sub Dispose() Implements IDisposable.Dispose
    Try
      If (_typeInfo IsNot Nothing) Then
        _typeInfo.ReleaseTypeAttr(_pTypeAttr)
      End If
      If (_object IsNot Nothing) Then
        Marshal.ReleaseComObject(_object)
        _object = Nothing
      End If
        Marshal.ReleaseComObject(_dispatch)
        _dispatch = Nothing
      End If
    Catch ex As Exception
    End Try
  End Sub
  Public Function GetPropertyNames() As String()
    Dim list As System.Collections.ArrayList = New System.Collections.ArrayList()
    Try
      For i As Integer = 0 To TypeAttr.cFuncs - 1
        Dim pFuncDesc As IntPtr = IntPtr.Zero
        Dim funcDesc As System.Runtime.InteropServices.ComTypes.FUNCDESC '() ????
        Dim strName As String = ""
        Dim strDocString As String = ""
        Dim strHelpFile As String = ""
        Dim dwHelpContext As Integer
        _typeInfo.GetFuncDesc(i, pFuncDesc)
        funcDesc = Marshal.PtrToStructure(pFuncDesc, GetType(System.Runtime.InteropServices.ComTypes.FUNCDESC))
        Select Case funcDesc.invkind
          Case System.Runtime.InteropServices.ComTypes.INVOKEKIND.INVOKE_PROPERTYGET
            _typeInfo.GetDocumentation(funcDesc.memid, strName, strDocString, dwHelpContext, strHelpFile)
            list.Add(strName)
        End Select
      Next
      Throw ex
    End Try
    GetPropertyNames = list.ToArray(GetType(String))
  End Function
  Public ReadOnly Property TypeName() As String
    Get
      TypeName = _typeName
    End Get
  End Property
  Public ReadOnly Property TypeFullName() As String
    Get
      TypeFullName = ComTypeLibrary.Name + "." + _typeName
    End Get
  End Property
  Public ReadOnly Property TypeDescription() As String
    Get
      TypeDescription = _typeDescription
    End Get
  End Property
  Public ReadOnly Property TypeHelpContext() As String
    Get
      TypeHelpContext = _typeHelpContext
    End Get
  End Property
  Public ReadOnly Property TypeHelpFile() As String
    Get
      TypeHelpFile = _typeHelpFile
    End Get
  End Property
  Public ReadOnly Property WrappedComObject() As Object
    Get
      WrappedComObject = _dispatch
    End Get
  End Property
  Public ReadOnly Property ComTypeLibrary() As ComTypeLibrary
    Get
      ComTypeLibrary = _comTypeLibrary
    End Get
  End Property
  Public ReadOnly Property TypeAttr() As System.Runtime.InteropServices.ComTypes.TYPEATTR
    Get
      TypeAttr = Marshal.PtrToStructure(_pTypeAttr, GetType(System.Runtime.InteropServices.ComTypes.TYPEATTR))
    End Get
  End Property
  Public ReadOnly Property TypeVersion() As String
    Get
      Dim version As String = String.Empty
      Try
        version = TypeAttr.wMajorVerNum.ToString() + "." + TypeAttr.wMinorVerNum.ToString()
      End Try
      TypeVersion = Version
    End Get
  End Property
End Class
ComTypeLibrary.vb
Imports System
Imports System.IO
Imports System.Reflection
Imports System.Reflection.Emit
Imports System.Text
Public Class ComTypeLibrary
  Private _typeLib As System.Runtime.InteropServices.ComTypes.ITypeLib
  Private _pTypeLibAttr As IntPtr = IntPtr.Zero
  Private _Name As String
  Private _Description As String
  Private _HelpFile As String
  Private _HelpContext As Integer
  Public Sub New(ByVal typeLib As System.Runtime.InteropServices.ComTypes.ITypeLib)
    _typeLib = typeLib
    _typeLib.GetLibAttr(_pTypeLibAttr)
    _typeLib.GetDocumentation(-1, _Name, _Description, _HelpContext, _HelpFile)
  End Sub
  Public ReadOnly Property Name() As String
    Get
      Name = _Name
    End Get
  End Property
  Public ReadOnly Property Description() As String
    Get
      Description = _Description
    End Get
  End Property
  Public ReadOnly Property HelpContext() As Integer
    Get
      HelpContext = _HelpContext
    End Get
  End Property
  Public ReadOnly Property HelpFile() As Integer
    Get
      HelpFile = _HelpFile
    End Get
  End Property
  Public ReadOnly Property TypeLibAttr() As System.Runtime.InteropServices.ComTypes.TYPELIBATTR
    Get
      TypeLibAttr = Marshal.PtrToStructure(_pTypeLibAttr, GetType(System.Runtime.InteropServices.ComTypes.TYPELIBATTR))
    End Get
  End Property
  Public ReadOnly Property TypeLibVersion() As String
    Get
      Try
        Version = TypeLibAttr.wMajorVerNum.ToString() + "." + TypeLibAttr.wMinorVerNum.ToString()
      End Try
      TypeLibVersion = version
    End Get
  End Property
  Public ReadOnly Property Version() As Version
    Get
      Version = New Version(TypeLibAttr.wMajorVerNum, TypeLibAttr.wMinorVerNum, 0, 0)
    End Get
  End Property
  Public Overrides Function GetHashCode() As Integer
    GetHashCode = TypeLibAttr.guid.GetHashCode() + TypeLibAttr.wMajorVerNum.GetHashCode() + TypeLibAttr.wMinorVerNum.GetHashCode()
  End Function
  Public Overrides Function Equals(ByVal obj As Object) As Boolean
    Dim comTypeLibrary As ComTypeLibrary = CType(obj, ComTypeLibrary)
    If (comTypeLibrary IsNot Nothing) Then
      If (TypeLibAttr.guid.Equals(comTypeLibrary.TypeLibAttr.guid)) Then
        If (TypeLibAttr.wMajorVerNum.Equals(comTypeLibrary.TypeLibAttr.wMajorVerNum)) Then
          If (TypeLibAttr.wMinorVerNum.Equals(comTypeLibrary.TypeLibAttr.wMinorVerNum)) Then
            Equals = True
            Exit Function
          End If
        End If
      End If
      Equals = MyBase.Equals(obj)
    Else
    End If
  End Function
  Public Overrides Function ToString() As String
    ToString = Name + " - " + Description
  End Function
End Class
IDispatch.vb
Imports System
Imports System.Text
_
Public Interface IDispatch
  Function GetTypeInfoCount() As Integer
  Function GetTypeInfo( ByVal iTInfo As Integer, _
                        ByVal lcid As Integer) As System.Runtime.InteropServices.ComTypes.ITypeInfo
  Function GetIDsOfNames(ByRef riid As Guid, _
                         ByVal rgsNames As String(), ByVal cNames As Integer, ByVal lcid As Integer, _
                         ByVal rgDispId As Integer()) As Integer
  Function Invoke(ByVal dispIdMember As Integer, ByRef riid As Guid, _
ByVal lcid As Integer,  ByVal dwFlags As Integer, _
ByRef pDispParams As System.Runtime.InteropServices.ComTypes.DISPPARAMS, _
ByVal pVarResult As Object(), _
ByRef pExcepInfo As System.Runtime.InteropServices.ComTypes.EXCEPINFO, _
ByVal pArgErr As IntPtr()) As Integer
End Interface
Post date: 3/25/2011 8:00:12 AM
