How can I reorder sheets in the draft environment in st6.
I know that I can reorder by right clicking the sheets and selecting reorder. This is quite a labor intensive operation, especially when there is over 100 sheets. Is there a way that it can be coded perhaps.
Thanks in advance
Nev
I can't see any API for that, so I believe that it is not...
I can't see any API for that, so I believe that it is not possible through normal API calls.
Re: I can't see any API for that, so I believe that it is not...
Ok thanks, Thats a bugger as reordering some 100 sheets in a draft is quite some task with the UI in SE
