How can i change the links using Solid Edge
When i copy any files from server to my PC then what is the way to change the respective links using Solid Edge document object through programatically. This can be achieved by using Revision Manager but i want to change it using solid edge.Changing the links means if i open that copied assembly in revision manager then it should not be showing any broken links.Please help
