How can we retrive the units of a document?
PLM World Member Genius PLM World Member Genius
In other words, under file propertie we set M, Inch mm and we want to retrive this infomation
SolidDNA,   dim objDoc as your SE document, you can refer...
SolidDNA,
dim objDoc as your SE document, you can reference the units of measure by
objDoc.UnitsOfMeasure.Item(x).Units
There are several types (Length, Angle, Mass etc) that you can reference by using it's item number (x):
item(1) = Linear
item(2) = angular
This will return an integer, to decode look up the UnitOfMeasure Enumerations in your SDK help file. So for linear units look at UnitOfMeasureLengthReadoutConstants Enumeration; 17 is milimeters, 15 is meters ect. Using some handy code and arrays you can match the integer with a string so you get text instead of numbers.
Hope this helps.
Re: SolidDNA,   dim objDoc as your SE document, you can refer...
Thank you Tom
Will notify the programmer on monday about this
Have a good weekend
Tom my programer found this as well, wanted to share.
He seems to prefer this. I'm not a coder so will let you debate which method is better. If you feel there is drawback let me know and I'll forward the info
He use igUnitDistance
http://dl2.plm.automation.siemens.com/solidedge/api/sesdk_web/UnitsOfMeasure.html#hs-inthistopic-5ba...
SolidEdgeConstants.UnitTypeConstants
And he was able to get the information. Explanation here might be short has i did not fully remember everything. Anyone who wantd to add more info are welcome to share.
