How change the material of partdocument
I have a programming to change partdocumet material,but it only can change the material name.
Set objDoc = objApp.Documents.Open(strFileName)
Set objPropertySets = objDoc.Properties
objPropertySets.Item("MechanicalModeling").Item("Material").Value = MaterialName
objDoc.Save
who can help me to sove this problem?
Posted by: zxm342500
Post date: 2/2/2013 9:28:45 PM
Use the ApplyMaterial command
my example:
objApp = GetObject(, "SolidEdge.Application")
objSEPart = objApp.ActiveDocument
strPropVal = lstMatl.Text
objMatTable = objApp.GetMaterialTable
objMatTable.ApplyMaterial(objSEPart, strPropVal)
Posted by: Mark Spencer
Post date: 2/4/2013 7:35:58 AM
