How do I copy sketches to Clipboard???
Hi all!
I want to copy  outline of sketches to Clipboard,and then paste it into another sketch.
I would like to how to achieve?
Please help!
Thanks!
Posted by: fat kids
Post date: 1/12/2010 2:54:59 AM
RE: How do I copy sketches to Clipboard???
If the second sketch does not exist then you are looking for:
Sketches.AddByTearOff method
If the second sketch exists, i guess that you have to add the profile elements in the first sketch to the part SelectSet:
'These lines are by heart. They might have a mistake. Sorry, no time for more right now.
oCircle2D=oPart.Sketches.Item(1).Profiles.Item(1).Circles2d.Item(1) 'First Circle in first profile in first sketch.
oMySelectSet=oPart.SelectSet
oMySelectSet.Add oCircle2D
oMySelectSet.Copy
oPart.Sketches.Item(2).Profiles.Item(1).Paste 'if there is an existing Profile in sketch 2 or
oMyProfile=oPart.Sketches.Item(2).Profiles.Add(oRefPlane) 'Create a new profile in sketch 2.
oMyProfile.Paste
oMyProfile.End (condition) 'See help
Posted by: Julian Guillo
Post date: 1/19/2010 3:46:00 AM
You may want to try the select set's "CopyProfile" method (there is a "CutProfile" method too). I believe you just add the profile to the select set and then call CopyProfile.
Posted by: R.D. Holland
Post date: 1/26/2010 4:19:42 AM
Thanks Julian Guillo and R.D. Holland!
Let's me try!
Posted by: fat kids
Post date: 1/28/2010 6:41:50 PM
