How do I get Asm mass in a VB form
How do I get the mass of a referenced ASM in a vb FORM?
For Par, as mentioned by anyone, Example below:
 Dim dblDensity As Double                                        'input
 Dim dblAccuracyIn As Double                                    'input Accuracy
 Dim dblVolume As Double                                          'output
 Dim dblArea As Double                                              'output
 Dim dblMass As Double                                              'output
 Dim dblCofGravity(1 To 3) As Double                          'output
 Dim dblCofVolume(1 To 3) As Double                         'output
 Dim dblGlobalMoments(1 To 6) As Double                  'output
 Dim dblPrincipalMoments(1 To 3) As Double               'output
 Dim dblPrincipalAxes(1 To 9) As Double                      'output
 Dim dblRadiiOfGyration(1 To 3) As Double                  'output
 Dim dblAccuracyOut As Double                                    'output Accuracy
 Dim lngStatus As Long                                                'output *
'* Someone said 'IngStatus As Integer'. It's wrong. (For me & VBA)
 Set app = GetObject(, "solidedge.application")
 Set act = app.ActiveDocument
 Set mdl = act.models.Item(1)
 Call mdl.ComputePhysicalProperties(dblDensity,dblAccuracyIn,dblVolume, dblArea, dblMass, _
     dblCofGravity(), dblCofVolume(), dblGlobalMoments(), dblPrincipalMoments(), dblPrincipalAxes(), dblRadiiOfGyration(), _
     dblAccuracyOut, lngStatus)
For Asm, I think, maybe it's this. (by Spy)
 Call obj.GetAssemblyPhysicalProperties(out System.Object, out System.Object, out System.Object, _
     ref System.Object, ref System.Object, ref System.Object, ref System.Object, ref System.Object, ref System.Object, _
     ref System.Object, ref System.Object, out System.Object, out System.Object)
More parameter than Par! Why?
Please teach me that kind of parameter or  correct method for getting the mass of Asm.
Posted by: Shoji Nakahara
Post date: 12/26/2011 1:00:00 PM
RE: How do I get Asm mass in a VB form
From SDK:
Sub GetAssemblyPhysicalProperties ( _
ByRef Mass As Double, _
ByRef Volume As Double, _
ByRef Area As Double, _
ByRef CenterOfMass As Array, _
ByRef CenterOfVolume As Array, _
ByRef GlobalMoments As Array, _
ByRef PrincipalAxis1 As Array, _
ByRef PrincipalAxis2 As Array, _
ByRef PrincipalAxis3 As Array, _
ByRef PrincipalMoments As Array, _
ByRef RadiiOfGyration As Array, _
ByRef IsSick As Boolean, _
ByRef UpdateStatus As Boolean _
Posted by: JR
Post date: 12/27/2011 6:54:10 PM
Thank you!
Post date: 12/28/2011 12:06:57 AM
