How does variable paste link really work ?
I am trying to (programatically) link variables from one part file to another by editing the formula field of variables.
I note that if part1 has a variable named : V310 ,
then when it is pasted manually as a link
@'C:\cd\Asm1.asm'!'159'
How does the variable name get changed from V310 to 159 -
Can anyone help me with this question ? ( I had thought it was a hex number, but it doesnt quite seem to work)
Richard
Smiley Embarassed)
Posted by: Richard Gass
Post date: 6/28/2005 11:18:16 PM
RE: How does variable paste link really work ?
Richard,
I took a look at the problem and I too cannot figure out how they do it. I'll keep looking into it and let you know if I find anything. I bet you'll have to get an answer from them on this one.
Posted by: Jason Newell
Post date: 7/3/2005 12:55:55 PM
Jason,
if i already knew what my link should be for eg. @'C:\SE Projects\Casing Test 2\Std Wall Front Right End Corner.psm'!'84d'
How would i go about linking (inter-part) programatically?
I tried setting the formula field to the above link but i am getting this error:
System.Exception:
System.Runtime.InteropServices.COMException (0x80010006): The connection terminated or is in a bogus state and cannot be used any more. Other connections are still valid. (Exception from HRESULT: 0x80010006 (RPC_E_CONNECTION_TERMINATED))
Posted by: Rony G
Post date: 9/7/2007 8:19:07 AM
