How get Occurence from StructuralFrame
Hi all,
I need get a Occurence object from a Section of StructuralFrame. I try use this code in VB.NET 2005:
     oframe.GetSections(i, sections)ForEach oframe In doc.StructuralFrames
      For x = 0 To i - 1oframe.ReturnOccurrenceForGivenSectionID(sections(x), obj, objocu)    Next
 Next
However, this method returns parameters "obj" and "objocu" = "nothing"
Parameter "section(x)" is OK because method SegmentCutLenght (sections(x), lenght, paramObj) returns valid value.
Have you any suggest?
Vaclav
Posted by: Vaclav Blahnik
Post date: 4/16/2009 4:06:58 AM
RE: How get Occurence from StructuralFrame
Vaclav,
Could you reply with a test Solid Edge file and complete example source code? You can .zip them up and attach them in a reply.
Posted by: Jason Newell
Post date: 4/17/2009 7:03:32 PM
Hi Jason,
there are source code and test model. See attachment.
 Vaclav
Post date: 4/19/2009 10:46:37 PM
