How to Add Toggle Button to a Ribbon Menu
Builder
Builder
Hi All,
I have recently started programing with Solid Edge.
Firstly "THANK YOU". The "Developer Forum" AND "The SolidEdgeCommunity by Jason Newel & Nathan Emler" helped me a lot in getting started.
I need to add a "Toggle Button"  to my Ribbon menu, which will represent a boolean value to my custom Addin.
How can i add toggle buttons?
I am using the Addin template from SolidEdgeCommunity GitHub.
Santosh
Santosh
Re: How to Add Toggle Button to a Ribbon Menu
Piece of cake since you're using the community templates. Here is the code to toggle the check state of a button.
C#
void _button1_Click(RibbonControl control)
    _button1.Checked = !_button1.Checked;
 Visual Basic
Private Sub _button1_Click(ByVal control As RibbonControl)
	_button1.Checked = Not _button1.Checked
End Sub
Jason Newell
Applications Architect
www.jasonnewell.net
Builder
Builder
Thank You
Santosh
