How to Give Dimension to a protrusion(thickness of object)
    I want to give dimension to a thickness of the object.
   I just created a rectangular through VB6. I can give dimansion to the length and breadth but I cant give dimension to thickness after the sketch is protruded.
And one more thing. How can I give driving dimension
I have attached the image of the model.
Posted by: Pritam Dulam
Post date: 8/11/2009 1:30:15 AM
RE: How to Give Dimension to a protrusion(thickness of object)
Hi me,
you must make a model like this:
Dim objEPProfArray(1 To 3) As Object 'SolidEdgePart.Profile
Set objEPProfile = objDoc.Sketches(1).Profiles(1)
Set objEPProfArray(1) = objEPProfile
Set objModel = objDoc.Models.AddFiniteExtrudedProtrusion(NumberOfProfiles:=1, _
ProfileArray:=objEPProfArray, ProfilePlaneSide:=igLeft, ExtrusionDistance:=0.1)
What is "driving dimension"?
jr
Posted by: JR
Post date: 8/11/2009 2:51:41 AM
This is the code I used to draw the sketch and protrude it.... what is the difference between ur's and mine. PLease explain in detail.
Set objRefPlane = objDoc.RefPlanes.AddParallelByDistance( _
                            ParentPlane:=objDoc.RefPlanes(1), _
                            Distance:=0, _
                            NormalSide:=igLeft, _
                            Local:=True)
    ' Create a new profile to use for the feature.
    Set objProfiles(1) = objDoc.ProfileSets.Add.Profiles.Add(objRefPlane)
    ' Get the model space origin relative to profile space.
    Call objProfiles(1).Convert3DCoordinate(x3d:=0, _
                                    y3d:=0, z3d:=0, _
                                    x2d:=dblX, y2d:=dblY)
    ' Draw a rectangle for the profile graphics.
    Dim LineAB As Line2d
    Dim LineBC As Line2d
    Dim LineCD As Line2d
    Dim LineAD As Line2d
    Set LineAB = objProfiles(1).Lines2d.AddBy2Points(0.05, 0.05, 0.05, -0.05)
    Set LineBC = objProfiles(1).Lines2d.AddBy2Points(0.05, 0.05, -0.05, 0.05)
    Set LineCD = objProfiles(1).Lines2d.AddBy2Points(-0.05, 0.05, -0.05, -0.05)
    Set LineAD = objProfiles(1).Lines2d.AddBy2Points(-0.05, -0.05, 0.05, -0.05)
    Call objProfiles(1).Relations2d.AddKeypoint(LineAB, igLineStart, LineBC, igLineStart, True)
    Call objProfiles(1).Relations2d.AddKeypoint(LineBC, igLineEnd, LineCD, igLineStart, True)
    Call objProfiles(1).Relations2d.AddKeypoint(LineCD, igLineEnd, LineAD, igLineStart, True)
    Call objProfiles(1).Relations2d.AddKeypoint(LineAB, igLineEnd, LineAD, igLineEnd, True)
    'objProfiles(1).Visible = False
    ' End and validate the profile.
    lngStatus = objProfiles(1).End(ValidationCriteria:=igProfileClosed)
    If lngStatus 0 Then
        MsgBox "Invalid Profile"
        Exit Sub
    End If
    Call objProfiles(1).Dimensions.AddDistanceBetweenObjects(LineAB, 0.05, -0.05, 0, _
                                                     True, LineCD, -0.05, -0.05, 0, True)
    Call objProfiles(1).Dimensions.AddDistanceBetweenObjects(LineBC, 0.05, 0.05, 0, _
                                                     True, LineAD, 0.05, -0.05, 0, True)
    ' Create the base protrusion feature.
    Set objModel = objDoc.Models.AddFiniteExtrudedProtrusion(1, _
                                    objProfiles, _
                                    igRight, _
                                    0.01)
Driving Dimension  are dimensions which when changed also changes the geometry of the object.
Post date: 8/11/2009 7:15:23 PM
Hi me,
how did you declared objProfiles ?
JR
Posted by: JR
Post date: 8/11/2009 8:16:59 PM
Hi me,
for the driving dimension you must set the property Constraint (of the dimension) to TRUE. For your example:
Dim dim1 As SolidEdgeFrameworkSupport.Dimension
Dim dim2 As SolidEdgeFrameworkSupport.Dimension
Set dim1 = objProfiles(1).Dimensions.AddDistanceBetweenObjects(LineAB, 0.05, -0.05, 0, _
Set dim2 = objProfiles(1).Dimensions.AddDistanceBetweenObjects(LineBC, 0.05, 0.05, 0, _
dim1.Constraint = True
dim2.Constraint = True
JR
Posted by: JR
Post date: 8/11/2009 8:45:41 PM
HI,
    But My main proble is still intact. I need to give dimension to the width of the solid after extrudedprotrusion is executed.........
please reply......
Post date: 8/12/2009 7:42:59 PM
if you want to change the ExtrusionDistance, you can do that with:
objModel.ExtrudedProtrusions.Item(1).Depth = 0.05
JR
Posted by: JR
Post date: 8/12/2009 8:20:56 PM
HI,
  No Dude I need to place a dimension to the protrusion.......
Post date: 8/12/2009 8:27:02 PM
you must define the dimensions in the sketch (profile), set the Constraint property of the dimension to TRUE and change the VALUE of the dimension.
Posted by: JR
Post date: 8/12/2009 8:52:59 PM
Re: RE: How to Give Dimension to a protrusion(thickness of object)
I think you cannot explicitly add a dimension to the newle created feature.
A dimension is automatically created for you.
If you want to access the feature dimensions created, you can use .GetDimensions
Dim nDims As Integer = 0
Dim featDims As Array = Array.CreateInstance(GetType(System.Object), 0)
oExtCutout.GetDimensions(nDims, featDims)
Hope this helps,
Paolo Marani
