How to Modify parts changing variables in assembly mode.
Hi all~
Ultimately, I'd like to modify several parts changing variables values in an assembly mode. and some features such as holes and radius are able to be suppressed.So I created an assembly in Solid Edge v20 first. The assembly has two simple box parts.Then, I made a Form using visual basic.net. That form consists of "width", "length" and "height"  also "Ok" button. When I type dimensions such as width, length .... in the form and Click Ok butto IN THE PART MODE, a simple box is changed as what i wanted. BUT! I could NOT modify parts in the assembly mode. because in the assembly mode, it contains only assembly constraint dimensions.So, I want to know How could I activate a part in assembly mode. Please give me any helps. Thank you.
With best regards,
Posted by: Doyoung Park
Post date: 11/1/2010 3:20:39 PM
