How to Retrieve Dimensions in Draftmode using VB.net
Hi All,
Guys I m new to solid Edge,
How to Select a Particular view in draft mode using VB.net
How to Retrieve Dimensions of that particular selected view using VB.net
Pls help.
Posted by: Aravindh R
Post date: 6/30/2011 2:02:18 AM
RE: How to Retrieve Dimensions in Draftmode using VB.net
dimensions are in sheet.dimensions collection
try this
Dim obj As Object
Dim X As Double
Dim Y As Double
Dim Z As Double
Dim ind As Integer
Dim keypoint As Boolean
For i = 1 to objSheet.Dimensions.count
Call objDimension.GetRelated(ind, obj, X, Y, Z, keypoint)
if obj.object.drawingview.index = my_view then
your code
end if
next
for the retrieve your selected view use the selectset propertie in app.windows.item(1).selectset
Eric
Posted by: BONNAUDET eric
Post date: 7/6/2011 11:49:55 PM
