How to access PathFinder, Properties in add-in?
Hi Jason,
I am developing Solid Edge Add-in in VC++. In this add-in there is Command bar as UI.
When add-in is running I can not access PathFinder.
Secondly when I access Properties, Properties Manager of Assembly, add-in gets terminated.
How can I access above things during add-in is running.
Do I need to add events, mouse events to achieve this? Please let me know.
Thanks in advance.
-Amit
Posted by: Amit Wadekar
Post date: 5/29/2012 5:08:44 AM
Re: How to access PathFinder, Properties in add-in?
Hello Jason,
Do u have any suggestions for this topic?
Please help me in solving these problems.
Thanks.
-Amit
Post date: 5/31/2012 11:46:00 PM
I'm trying to do this and so far have been unable to locate by moving over PF. I can locate a part if I start a command and use the mouse API and set the filter to seLocatePart.
When those other commands are started, you command is terminated. You cannot access the dialogs SE presents to the user.
Posted by: R.D. Holland
Post date: 6/1/2012 5:20:58 PM
It turns out this is not possible Smiley Sad
Sure seems like we should add this capability. Perhaps if there are requests next week at Solid Edge University we would feel compelled to add it. I didn't say that. I have not been on this board ...
Post date: 6/4/2012 3:42:43 PM
Hello R.D.Holland,
Thanks for your reply.
-Amit
Post date: 6/5/2012 1:51:45 AM
