How to add AddByGeometry() in Assembly
I’m trying to create a program that can place coordinate systems easily by geometry and give them a particular name in the assembly environment. I don’t have problems with adding a coordinate system using a X, Y, Z values but when I try to add it by geometry. I’m using the mouse event to select a vertex and I want to use this vertex to place the coordinate system relative to existing geometry.
Eef de Klerk
Posted by: Eef de Klerk
Post date: 8/15/2011 2:56:18 AM
