How to add a vertical or horizontal dimension on drawingview
Hello
i search for add a vertical or horizontal dimension on drawingview
i use the "AddDistanceBetweenObjects" method
Set objDimension = objdims.AddDistanceBetweenObjects(Drawing.GraphicMembers.Item(obj1).Reference, posX1, posY1, 0, True, Drawing.GraphicMembers.Item(obj2).Reference, posX2, posY2, 0, True)
with posX1, posY1 and posX2, posY2 the position about the two key point (i'm not sure about that)
objDimension.MeasurementAxisDirection = True (for use the axis)
objDimension.Axis = ?????
how to set the axis ? or what is the good method ?
Sorry for my english
Posted by: BONNAUDET eric
Post date: 7/6/2011 10:47:52 PM
RE: How to add a vertical or horizontal dimension on drawingview
Up
Any boby have solution ?
eric
Post date: 8/9/2011 9:03:18 PM
Hello, I've have the same problem. Try this, works ok.
objdims.AxisMode = SolidEdgeFrameworkSupport.DimAxisModeConstants.igDimAxisModeExplicit
Sinex/ Eric, I am desesperate because I don't know to do a flange in a sheet metal. Can you help me?
Regards.
Posted by: Javier C
Post date: 10/31/2011 1:05:23 AM
for edit the part in assembly.
please help me..
Posted by: prasad k
Post date: 10/31/2011 1:14:12 AM
sorry Javier i haven't try tio do that, thanks you for your answer but the result isn't good , i don't understand how to use , posX1, posY1, , posX2, posY2 and how to choose horizontal or vertical dimension
Prasad : Your question is unclear
Post date: 11/4/2011 12:49:51 AM
