How to add an icon beside the tree node in the treeview of Solid Edge assembly document?
Dear all,
I am now developping a version control software for Solid Edge.
Usually, when engineers open an assembly document in the Solid Edge, there will be a treeview (which indicates the parts list) in the "Assembly PathFinder".
Now, I want to let engineers know which parts are checked out.
So, I will add an icon beside each tree node in the treeview.
For parts which are checked out, a tick ("V") will be added to the respective tree nodes.
Otherwise, a lock icon will be added.
Has Solid Edge provided such function?
if not, is there any other methods to implement such function?
Thanks!
William
Posted by: william Huang
Post date: 4/27/2011 4:20:07 AM
RE: How to add an icon beside the tree node in the treeview of Solid Edge assembly document?
I find that Solid Edge INSIGHT can implement such function.
How can I use INSIGHT API to implement the function in my program?
Post date: 4/27/2011 5:07:10 AM
