How to add balloon on drawingview
i want to add a balloon on a drawingview by the  "AddByTerminator" method but my code don't work
I took the code given in the example of the SDK and i modify it
Dim objApp As SolidEdgeFramework.Application
Dim objDoc As SolidEdgeDraft.DraftDocument
Dim objSheet As SolidEdgeDraft.Sheet
Dim objCircle As SolidEdgeFrameworkSupport.Circle2d
Dim objBalloons As SolidEdgeFrameworkSupport.Balloons
Dim objLine As SolidEdgeDraft.DVLine2d
' Report errors
Const PI = 3.14159265358979
' Create/get the application with specific settings
On Error Resume Next
Set objApp = GetObject(, "SolidEdge.Application")
If Err Then Err.Clear
   Set objApp = CreateObject("SolidEdge.Application")
   Set objDoc = objApp.Documents.Add("SolidEdge.DraftDocument")
   objApp.Visible = True
   Set objDoc = objApp.ActiveDocument
End If
' getting the Active Sheet object
Set objSheet = objDoc.ActiveSheet
' getting the Balloons collection object on the active sheet
Set objBalloons = objSheet.Balloons
Set Drawing = objDoc.Sheets.Item(1).DrawingViews.item(1)
Set objLine = Drawing.DVLines2d.Item(1)
' adding two balloons on the active sheet
Set objBalloon = objBalloons.AddByTerminator(TerminatorObject:=objLine, X1:=0.75, Y1:=0.05, z1:=0, keyPoint1:=True)
' Release objects
Set objApp = Nothing
Set objDoc = Nothing
Set objSheet = Nothing
Set objCircle = Nothing
Set objBalloons = Nothing
Posted by: BONNAUDET eric
Post date: 6/29/2011 11:53:40 PM
RE: How to add balloon on drawingview
I have find the solution
the good code is :
Set objBalloon = objBalloons.AddByTerminator(TerminatorObject:=objLine.Reference , X1:=0.75, Y1:=0.05, z1:=0, keyPoint1:=True)
Post date: 6/30/2011 4:00:01 AM
