How to add the angle relationship
Public Function AddAngular( _
ByVal Element1 As Object, _
ByVal Element2 As Object, _
ByVal ReverseElement1Direction As Boolean, _
ByVal ReverseElement2Direction As Boolean, _
ByVal MeasureElement1 As Object, _
ByVal MeasureElement2 As Object, _
ByVal Angle As Double, _
ByVal MeasureToPositiveSide As Boolean, _
ByVal MeasureFromPositiveSide As Boolean, _
ByVal MeasureCCW As Boolean _
) As AngularRelation3d
I want to make angle relationship in two plane's of two different parts
I have used the above API but enable to do this.
Please suggest me any solution for this.
Posted by: Yogesh Shinde
Post date: 11/1/2012 4:03:47 AM
