How to add the angle relationship
Please tell me how to add the angle relationship in solid edge with .net API.
Please share example code.
Re: How to add the angle relationship
Hi @Sam57,
I have made an example using a part from the Training folder.
The example first adds planar and axial relationships, which are taken from the example in the SDK Help.
I use the ID of the faces to get them from the Body object.
Hope you find this helpful.
To @jnewell: If you like, the example can be included in the Community examples.
JB
SE 2020, VS2017
