How to assign a Material from Material table to a psm or par file
Hello, I need help from smart guys!
I am trying to assign a all material properties from the Material table to a psm or par file.
Thank you!
Posted by: Mariano Spini
Post date: 10/2/2010 3:23:53 AM
RE: How to assign a Material from Material table to a psm or par file
Find attached a screenshot of the Spy.
The 'properties' you see are the properties of the .psm or .par document.
Good Luck!
Wouter (Erwo)
Posted by: Wouter Sloof
Post date: 10/4/2010 10:45:42 PM
Wouter,
Many thanks for your unswer.
Let me see if I understand, If I want to assign all properties for Steel to a par file I have to surft each propertie ("Coef. of Thermal Exp", "Elongation", "Face Style", etc.) and assign the value taken from the Material Table to the par file?
Mariano.
Post date: 10/6/2010 12:50:53 AM
Mariano,
What your saying is probably the thing you should do. Solid Egde is probably doing the same thing in the background when you change the material. But I'm not sure, never done it.
It would say, try by beginning to test what the effect is of changing just the value of the material property, maybe that's enough.
Wouter
Post date: 10/6/2010 8:52:12 PM
If you apply material from material table, you need't send any values.
For apply material use:
Set ObjPartDoc = objApp.ActiveDocument
Set ObjMattable = objApp.GetMaterialTable
Call ObjMattable.ApplyMaterial(ObjPartDoc, MaterialName)
If you need calculate density use way from Solid edge Programing Help:
ComputePhysicalProperties
Posted by: Jiri Marek
Post date: 10/11/2010 9:42:12 PM
