How to call Save as dialog?
Hi All!
How to call "Save as..." dialog in VB code? I need to call "Save as..." dialog during run my macro, and I want to paste new filename (As String) in the "file name" field.
I don't want use SaveAs method, becouse user must select path himself in "Save as" dialog.
Is it possible?
Posted by: Anton Bykov
Post date: 6/30/2010 1:30:34 AM
RE: How to call Save as dialog?
for active File you can use:
objApp.GetSaveAsFileName(ByRef LinkSaveOption As Integer, ByRef SelectedFilter As Integer, Optional ByVal InitialFilename As Object = Nothing, Optional ByVal FileFilter As Object = Nothing, Optional ByVal FilterIndex As Object = Nothing, Optional ByVal Title As Object = Nothing, Optional ByVal IsTemplate As Object = Nothing) As Object
or:
objapp.StartCommand(57604)
Posted by: JR
Post date: 7/5/2010 11:21:54 PM
JR,
I use:
Call objApp.GetSaveAsFileName(lnkSO, SelFil, NewFileName, "Part (*.par),*.par")
Then "SaveAs" dialog is opens, I click the "Save" button, "SaveAs" dialog is closes and... nothing happens , part document doesn't save.
I don't want use "objApp.StartCommand (57604)", because I need NewFileName (As String) in File Name field.
Why objApp.GetSaveAsFileName(...) doesn't work?
Post date: 7/6/2010 12:27:15 AM
The GetSaveAsFileName ist only the dialog to save.
You must call the SaveAs(...) method after.
Like this:
Dim sFileName as Object
sFileName =objApp.GetSaveAsFileName(lnkSO, SelFil, NewFileName, "Part (*.par),*.par")
If TypeOf sFileName Is String Then 'if cancel the type is boolean with false
objDoc.SaveAs(sFileName)
End If
Posted by: JR
Post date: 7/6/2010 8:49:58 PM
JR,
Are you sure, what "If TypeOf sFileName Is String Then" is correctly? Maybe not "String", becouse Micrisift Visual Basic shows "Compile error: Expected: Object or type name"
Post date: 7/7/2010 8:52:27 PM
I try next code, and it worked:
Dim sFileName As String
        sFileName = objApp.GetSaveAsFileName(lnkSO, SelFil, NewFileName, "Part (*.par),*.par")
            If Not sFileName = False Then
            objDoc.SaveAs (sFileName)
            End If
Thank you!
Post date: 7/7/2010 9:45:14 PM
Hi Frantic,
the method TypeOf is in vb6 only for objects and not for type string. In Visual Basic 2005 for all types.
I use VS2005/2010. Are you work with vb6?
Posted by: JR
Post date: 7/7/2010 10:52:58 PM
Hi, yes, I work with VB6
Post date: 7/7/2010 11:29:59 PM
