How to chamge Sheet setup
HI,
    I want to change the sheet setup of draft in solid edge.
I have used following code.
objDoc.Sheets(1).SheetSetup.SheetSizeOption = igIsoA4Wide
objDoc.Sheets(1).SheetSetup.DefaultDrawingViewScaleOption = igEng1To1
objDoc.Sheets(1).SheetSetup.PaperUnits = igUnitMillimeters
objDoc.Sheets(1).SheetSetup.PaperUnitsPrecision = igPrecisionOnes
Call objDoc.Sheets(1).SheetSetup.SetDefaultDrawingViewScale(1, 1)
objDoc.Sheets(1).Background = objDoc.Sheets(1)
objDoc.Sheets(1).BackgroundVisible = True
objDoc.Sheets(1).Visible = True
i do get the sheet changed but thr problem is, i cant get background sheet.
Bye..
Posted by: Pritam Dulam
Post date: 7/30/2009 10:39:33 PM
RE: How to chamge Sheet setup
you should use the sheets collections of objDoc.Sections.WorkingSection.Sheets or objDoc.Sections.BackgroundSection.Sheets respectively.
Posted by: Wolfgang Kunert
Post date: 7/30/2009 10:57:18 PM
could u explai it a bit more??
Post date: 7/30/2009 11:18:36 PM
yes,
instead of using
objDoc.Sheets(1).SheetSetup ....
use
objDoc.Sections.WorkingSection.Sheets(1).SheetSetup ...
to configure the foreground sheets. For the background sheets replace WorkingSection by BackgroundSection
Post date: 7/30/2009 11:54:26 PM
