How to change drawing view sheet
Hello!
How can I programatically change sheet that drawing view belongs to ?
I can do it manually. But drawing view's property "Sheet" is read-only , so I can't set it.
Any other ideas?
BTW, I tried to use DrawingView.Visible read-write property, but each time I tried to set it, I got a crash.
Does somebody came up to this issue? Is this SE bug?
Posted by: P Sh
Post date: 6/5/2010 11:41:34 PM
RE: How to change drawing view sheet
The drawing view is an element of Sheet.
Sheet -> DrawingViews -> DrawingView
you can try use the clipboard to move (cut and paste) the drawing view to another sheet.
Posted by: JR
Post date: 6/7/2010 12:49:57 AM
