How to change modelLink of a single view ?
I need to change the 3D source of a specific view ?
I manage to add new modelLink to the draft document, I also manage to change the source of the modelLink.
What I need to do is change th modelLinkof the view without any modification on the other view taht share the same source.
For exemple :
  • Copy all data from Sheet 1
  • Create a new Sheet
  • Paste all in the new sheet
  • Change 3D source only for the new sheet
Thanks for your help.
Romuald
Romuald BERTIN
Re: How to change modelLink of a single view ?
My workflow for this:
- Cut only this views where you whont to replece source files,
- Past them to a new draft,
- Change source file by edit links tool or from revision (designe or something like this, i have ST8 Smiley Happy) manager,
- Update views,
- Copy views and past to primary draft
I think You must use temporary draft file for this. Im not shure this will help You but i whont share with You my workflow for situation like this.
SE ST9 + TC 10.1.7
Thanks for your workflow, I end using something pretty similar :
  • Copy View and linked annotations and dimensions
  • Create new draft document
  • Change source of the modellink in the new draft
  • Update view
  • Copy modify view and linked annotations and dimensions
  • Close the temp Draft
  • Delete view and linked annotations and dimensions in the original draft
  • Paste modified view and linked annotations and dimensions
Romuald BERTIN
