How to change path of a CopyConstruction?
I have been trying to change the path of a CopyConstruction by using the PutFileName method.  It does not update it into the object; however, if I change the FileName in Solid Edge Spy it updates it.  Any idea why this is not working or how to properly do this?  I appreciate anyone's assistance with this problem.  I am placing the code I've been trying below:
if(filename.find(xref->getCadName()) != wstring::npos)     //convert wstring to string
     string new_name(new_filename.begin(), new_filename.end());
     new_name.assign(new_filename.begin(), new_filename.end());
     _bstr_t cppstrings(new_name.c_str());
     copy->PutFileName(cppstrings);
     _bstr_t temp_name = copy->FileName;
CopyConstructionPtr copy = construct_copies->Item(i);
wstring filename(copy->GetFileName());
Posted by: Derek Rollinson
Post date: 4/29/2010 4:57:40 AM
RE: How to change path of a CopyConstruction?
Dear
Even I had a same problem but I could not resolved it! Sorry..
But manually you can change in Revision Manager but I have used VB.NET to change the copied parts in a part or assembly environment.
Try with Revision Manager may by you will get it.
All the Best
Sandeep S
Posted by: Sandeep Shewale
Post date: 4/29/2010 6:45:01 PM
Sandeep,
How did you do this with Revision Manager? I have been trying but when I use PutFullName I get a com exception saying that it is a read only property? It also looks like RevisionManager might be opening the file as readonly, any idea on this? I appreciater your assistance.
RevisionManager::ILinkedDocsAutoPtr linked_docs = rev_doc->GetLinkedDocuments();
for (long i=1; iCount; i++)
RevisionManager::IDocAutoPtr doc = linked_docs->GetItem(i);
wstring filename = const_cast((LPCTSTR)doc->Get_FullName());
_bstr_t name(new_name.c_str());
doc->_FullName = name;
rev_doc->SaveAllLinks();
Post date: 4/30/2010 2:13:10 AM
