How to change the color of the tree node in the treeview of the assembly document?
Dear all,
I am now developping a version control software for Solid Edge.
Usually, when engineers open an assembly document in the Solid Edge, there will be a treeview (which indicates the parts list) in the "Assembly PathFinder".
Now, I want to let engineers know which parts are checked out.
So, I want to change the color of the tree node in the treeview.
For parts which are checked out, the color will be changed to red for the respective tree nodes. (refer to the red node in the attachment)
Otherwise, the color of the node will be normal.
Is there any methods to implement such function?
Thanks!
William
Posted by: william Huang
Post date: 4/28/2011 5:23:47 AM
