How to check for errors in sheet metal?
I am making some changes to the variables and every once in a while a part sheet metal comes up with an error in the Error Assistant.. For example: Hole 1 Failed Operation unsuccessful or Flatten 1 Failed System Error..
Is there any way to get the list of errors from the error assistant? or just to know if a part has any errors on it at all?
Posted by: maury terneus
Post date: 6/27/2013 10:18:08 AM
Yuou should iterate through the DesignEdgebarFeatures and query the status of each feature. This gives you its status (OK, Failed, Warned, RolledBack, Suppressed) and in case of failure, the error description itself.
Posted by: Martin Bernhard
Post date: 6/28/2013 3:31:52 AM
Martin,
Thanks for the reply! I am trying to do as you said but I am failing Smiley Sad
Dim smDoc As SheetMetalDocument = CType(_objApplication.ActiveDocument, SheetMetalDocument)
Dim edgebarFeatures As EdgebarFeatures = smDoc.DesignEdgebarFeatures
For k As Integer = 1 To edgebarFeatures.Count
Dim feature As Object = edgebarFeatures.Item(i)
Dim objectType As SolidEdgeConstants.ObjectType = CType(feature.Type, SolidEdgeConstants.FeatureTypeConstants)
Dim statusdsc As Object
Dim result As FeatureStatusConstants = feature.Status()
Next
Everything is showing as OK even tho i see errors. Am i doing something wrong?
Post date: 6/28/2013 10:09:45 AM
Nvm, i think i found the problem! wrong index!
Post date: 6/28/2013 10:20:14 AM
Perfect, thank you Smiley Happy
Post date: 6/28/2013 10:42:48 AM
