How to convert unit?
Hi
Using ComputePhysicalProperties, I can get the mass of my model in "database" unit.  How do I use UnitsOfMeasure.FormatUnit to convert this value to a known unit?
Posted by: Pascal Boivin
Post date: 9/3/2009 8:04:38 AM
RE: How to convert unit?
Oh! I don't need to use FormatUnit, I just need to know what is the database unit for the mass. (e.g. how to convert it to lbs to kg).
Post date: 9/3/2009 8:26:13 AM
I found it! The mass must be multiplied by 1190 to obtain kg. I have absolutly no idea what is this value. I found it by trial and errors. To obtain a value in pounds, the value must be multiplied by 2623.45734.
Post date: 9/3/2009 10:11:24 AM
Pascal,
I don't think you are right.
AFAIK internal units for Mass are Kg.
Distance units are Meters
Angle units are Radians
Area: m2
Volume: m3
Density: Kg/m3
Maybe you didn't update the solid or you made a mistake calculating the mass.
Hope this helps...
Posted by: Julian Guillo
Post date: 9/7/2009 2:58:40 AM
Can you please upload the code to change the advanced units in a par file to change say frm lbm to kg as not sure how it is done..thanks
Posted by: Allan Anderton
Post date: 12/5/2011 1:36:36 AM
