How to copy (C#) data from "Track changes" modal in Draft?
After each change of the model, the Draft module displays a table with "Track changes" (dimensions etc.).
The question is - is there any API-like method to copy these "changes" (all the values) programmatically? Currently I'm using the Automation API from .Net, but it's not a "well formed" solution.
Re: How to copy (C#) data from "Track changes" modal in Draft?
My question is going more important every day, so I will ask in some other way:
how can I get the Data from any Modal Solid Edge windows (without using the automation API)?
