How to copy data from Excel to Family members dimensions?
Hi!
Now I'm writing a macro (into Excel VBA) that retrieves data from Excel and create family of details in active Part. Now
the program can create family members by means of FamilyMembers.Add Method. But I am at a loss what command can
substitute value of a variable for the family members.  I found in the manual sesdk this phrase:  "To modify the
value of a variable of a family member, obtain the family member, then change the value using the member's Value
method." But I can’t understand what to do.  Does anybody know anything about it?  I’m not a programmer, but I’m
learning.
This my code, which add Family members:
Private Sub CommandButton1_Click()
    Dim objApp As SolidEdgeFramework.Application
    Dim objDoc As SolidEdgePart.PartDocument
    Dim objFamilys As SolidEdgePart.FamilyMembers
    Dim objFamily As SolidEdgePart.FamilyMember
    Dim cA As String, cB As Double, myRow As Integer
    ' Report errors
    Const PI = 3.14159265358979
    ' Create/get the application with specific settings
    On Error Resume Next
    Set objApp = GetObject(, "SolidEdge.Application")
    If Err Then
        Err.Clear
        objApp.Visible = True
    Else
        Set objDoc = objApp.ActiveDocument
    End If
    objApp.DelayCompute = True
            myRow = 2
            With ActiveWorkbook.ActiveSheet
                Do While Not IsEmpty(.Cells(myRow, 1))
                cA = CStr(.Cells(myRow, 1))
                cB = CStr(.Cells(myRow, 2))
                Set objFamilys = objDoc.FamilyMembers.Add(cA)
                Set objFamily = objFamilys.Item(1)
                myRow = myRow + 1
                Loop
            End With
        odjApp.DelayCompute = False
    Set objApp = Nothing
    Set objDoc = Nothing
    Set objFamily = Nothing
End Sub
How copy data from Excel to family members dimensions??
Thanks for the help!
Posted by: Anton Bykov
Post date: 5/6/2010 1:31:57 AM
RE: How to copy data from Excel to Family members dimensions?
Maybe following should work (If I understand correctly, cB is the value that you want to put in the variable):
objFamilys.Item(1).Variables("VarName").Value = cB
Not sure if cB should be a string.
- Sanjay Kulkarni[script removed]
Posted by: Sanjay Kulkarni
Post date: 5/6/2010 2:58:23 AM
Sanjay, Thank you for your answer!
Realy, in my code cB is the value from Excel cell (for example 10). Active part has 3 variables: A, B and C.
I try to use this code now, but it don't work. (In next code DN - name member; cA, cB, cC - values from Excel, which correspond the value variables A, B, C.)
Dim DN As String, cA As String, cB As String, cC As String, myRow As Integer
myRow = 2
                DN = CStr(.Cells(myRow, 1))
                cA = CStr(.Cells(myRow, 2))
                cB = CStr(.Cells(myRow, 3))
                cC = CStr(.Cells(myRow, 4))
                Set objFamilys = objDoc.FamilyMembers.Add(DN)
                objFamilys.Item(1).Variables(A).Value = cA
                objFamilys.Item(1).Variables(B).Value = cB
                objFamilys.Item(1).Variables(C).Value = cC
                myRow = myRow + 1
                Loop
            End With
Maybe I was wrong to do something? (sorry for my english)
Post date: 5/6/2010 5:27:43 AM
[script removed]
Frantic,
Try
               objFamilys.Item(1).Variables("A").Value = cA
                objFamilys.Item(1).Variables("B").Value = cB
                objFamilys.Item(1).Variables("C").Value = cC
If it still does not work, post your sample part here and I can explore and try to find the solution.
[script removed]
Post date: 5/6/2010 6:04:18 AM
Sanjay, I tried, but it still doesn't work.
Maybe cA, cB, cC is not As String?
Try it, please. Thank you!
Post date: 5/6/2010 6:23:05 AM
Frantic,
the following statement worked for me:
pDoc.FamilyMembers(1).Variable("Ht1").Value = 200
where Ht1 represents a sketch dimension.
One mistake I made was variables. it should be variable.
Also note that 200 is not a string value. Variables can't accept string values.
Post date: 5/6/2010 7:25:46 AM
Sanjay,
strangely, but it don't work for me.
Are you sure, what Ht1 is dimension, but not variable?
Post date: 5/7/2010 2:53:51 AM
Frantic,
Isn't it possible to use the variables.edit method? There are indeed some issues regarding variables and dimension, see other discussions on this site.
pDoc.FamilyMembers(1).Variables.Edit ("Ht1","200") (both name and value should be string data type.)
Posted by: Wouter Sloof
Post date: 5/9/2010 10:28:45 PM
ErWo,
variables.edit method don't work. It edit variables of parent part, but not variables of each members of family.
Maybe I expressed the problem is unclear. I wont to move data from Excel (Pic1) to table of family of parts (Pic2).
This my code, which add members of family to table of FOP.
    ' Report errors
    If Err Then
        Err.Clear
    Else
    End If
            myRow = 2
                myRow = myRow + 1
                Loop
            End With
    Set objFamilys = Nothing
End Sub
In SeSdk described this methods and properties, bot I don't know, how it use
NameDescription AddAdds an occurrence of the referenced object. AddFamilyVariableThis method adds a variable to a family of parts. CopyThis method copies a specified FamilyMember object to a new FamilyMember object ItemThis method returns the items in a collection, providing a mechanism for iterating through all or part of the items. RemoveFamilyVariableThis method removes a variable from a FamilyMember object.
Properties
NameDescription ApplicationThe Application object in which the referenced object is active. CountReturns the number of objects in the referenced collection. FamilyVariableReturns a Dimension or Variable object with a specified array for the referenced FamilyMember object. FamilyVariableCountReturns the number of variables defined in the referenced FamilyMember object. ParentReturns the parent object for the referenced object.
AddSuppressedFeatureThis method adds a feature to the list of suppressed features of the referenced FamilyMember object. ApplyApplies the current configuration settings and redisplays the object. DeleteDeletes the referenced object. GetDimensionsThis method returns the dimensions for the referenced object. PopulateCreates a Part document for the referenced FamilyMember object. RemoveSuppressedFeatureThis method removes a feature from the list of suppressed features for the referenced FamilyMember object.
Properties NameDescription ApplicationThe Application object in which the referenced object is active. AttributeSetsReturns the AttributeSets collection object for the referenced object. DescriptionDescription Property DisplayNameThis read-only String property returns the display name for the referenced object. DocumentNameSets and returns the name of the full-path specification of the PartDocument name that contains the referenced DividedPart or FamilyMember object. EdgebarNameThis read-only property returns the Edgebar name of the referenced object. IsAttributeSetPresentReturns True if a specified Attribute Set exists on the referenced object. NameReturns the name of the referenced object. ParentReturns the parent object for the referenced object. StatusReturns the status of the specified object. SuppressedFeatureReturns the suppressed feature having a specified index of a part in a family. SuppressedFeatureCountReturns the number of suppressed features in a family of parts. SystemNameThis read-only String property returns the system name for the referenced object. TypeSpecifies the type of the object being referenced. ValueReturns the name of the application, the value of a dimension, the value of a custom property, or the value of a variable. VariableReturns a Variable object having a specified index for the referenced FamilyMember object. VariableCountReturns the number of variables in a FamilyMember object.
Post date: 5/10/2010 8:16:29 AM
I'm so happy!! I did it!!!
Just:
objFamilys.AddFamilyVariable ("A")
objFamilys.AddFamilyVariable ("B")
objFamilys.AddFamilyVariable ("C")
and:
objFamilys.Add (DN)
objFamilys(DN).Variable("A").Value = cA
Thank you all for help to me!
Post date: 5/11/2010 4:54:51 AM
