How to create Draft Document from a part File
HI,,
   I want to create a draft document from a part file the way we do manually in solid edge.
PLz help.
A code snippet will be helpfull.
Posted by: Pritam Dulam
Post date: 7/27/2009 8:56:54 PM
RE: How to create Draft Document from a part File
HI all,
         Is ther any APi to do it.
Post date: 7/27/2009 10:54:42 PM
Or do I have to create awhole parts views on a draft file again??
Post date: 7/27/2009 11:14:17 PM
here a short code snippet (VB6) which creates a drawingview from a given part file on the active (empty) drawing file:
        Set objModelLink = objDftDoc.ModelLinks.Add(strParFile)
        Set objDrawingView = objDftDoc.ActiveSheet.DrawingViews.Add(From:=objModelLink, Orientation:=igTopView, Scale:=1#, x:=0, y:=0)
Posted by: Wolfgang Kunert
Post date: 7/28/2009 8:04:33 AM
Thanks a lot.
Post date: 7/28/2009 7:07:41 PM
