How to create a addin with c#?
Hi,Jason,I created a addin using c# in VS2008, but thers is no Icon in SE, would you give me a new simple sample only for c#?
Maybe, you can give me a PPT to decribe the process of createing the c# addin solution.
By the way, how to using "SetAddinInofEX"?
Thank you very much!
Posted by: assassin 007
Post date: 11/18/2008 8:51:55 PM
RE: How to create a addin with c#?
Hi, Jason, would you help me to check this project? And add a command to it? Thanks!
using System;
using System.Collections.Generic;
using System.Text;
using SolidEdgeFramework;
using SolidEdgePart;
using System.Runtime.InteropServices;
using Microsoft.Win32;
using System.Reflection;
namespace ttt
    [GuidAttribute("E596FF7A-55E2-4ba5-9551-E27318FCE950"),ProgId("MyAddIn.Addin"),ComVisible(true)]
    public class tts : SolidEdgeFramework.ISolidEdgeAddIn
        private SolidEdgeFramework.AddIn m_addin;
        private SolidEdgeFramework.Application m_application;
        #region ISolidEdgeAddIn ??
        void ISolidEdgeAddIn.OnConnectToEnvironment(string EnvCatID, object pEnvironmentDispatch, bool bFirstTime)
            //throw new NotImplementedException();
            //m_addin.SetAddInInfo();
        void ISolidEdgeAddIn.OnConnection(object Application, SeConnectMode ConnectMode, AddIn AddInInstance)
            m_application = Application as SolidEdgeFramework.Application;
            m_addin = AddInInstance;
            AddInInstance.GuiVersion = 1;
        void ISolidEdgeAddIn.OnDisconnection(SeDisconnectMode DisconnectMode)
            if (m_addin != null)
                Marshal.ReleaseComObject(m_addin);
                m_addin = null;
            if (m_application != null)
                Marshal.ReleaseComObject(m_application);
                m_application = null;
        #endregion
        #region "Regasm.exe functions" // Called by Regasm.exe
        [ComRegisterFunctionAttribute()]
        static void RegisterServer(Type t)
            RegistryKey baseKey = null;
            RegistryKey summaryKey = null;
            AssemblyTitleAttribute titleAttribute = null;
            AssemblyDescriptionAttribute descriptionAttribute = null;
            try
                baseKey = Registry.ClassesRoot.CreateSubKey(@"CLSID\{" + t.GUID.ToString() + "}");
                if (baseKey != null)
                    // Tell Solid Edge to automatically load your addin
                    baseKey.SetValue("AutoConnect", 1);
                    // Write title
                    if (t.Assembly.IsDefined(typeof(AssemblyTitleAttribute), true))
                        titleAttribute = (AssemblyTitleAttribute)AssemblyTitleAttribute.GetCustomAttribute(t.Assembly, typeof(AssemblyTitleAttribute));
                        baseKey.SetValue("409", "xxxxx"/*titleAttribute.Title*/);
                    // Write description
                    if (t.Assembly.IsDefined(typeof(AssemblyDescriptionAttribute), true))
                        descriptionAttribute = (AssemblyDescriptionAttribute)AssemblyDescriptionAttribute.GetCustomAttribute(t.Assembly, typeof(AssemblyDescriptionAttribute));
                        summaryKey = baseKey.CreateSubKey("Summary");
                        summaryKey.SetValue("409", descriptionAttribute.Description);
                    // Write required registry entries for a Solid Edge Addin
                    // See secatids.h in C:\Program Files\Solid Edge VXX\SDK\include
                    // CATID_SolidEdgeAddIn
                    baseKey.CreateSubKey(@"Implemented Categories\{Categories\{26B1D2D1-2B03-11d2-B589-080036E8B802}");
                    // Specify the Environment Categories that you want you addin // to work in
                    // CATID_SEApplication
                    baseKey.CreateSubKey( @"Environment Categories\{26618394-09D6-11d1-BA07-080036230602}");
                    // CATID_SEPart
                    baseKey.CreateSubKey(@"Environment Categories\{26618396-09D6-11d1-BA07-080036230602}");
            catch { }
            finally
                    baseKey.Close();
                    baseKey.Close();
        // Here we cleanup any registry values left from Regasm /u.
        [ComUnregisterFunctionAttribute()]
        static void UnregisterServer(Type t)
            try
                Registry.ClassesRoot.DeleteSubKeyTree(@"CLSID\{" + t.GUID.ToString() + "}");
            catch { }
        #endregion
Post date: 11/19/2008 3:05:37 PM
I register this dll using "regsvr32", but system tell me that there is no entry point.
Post date: 11/19/2008 3:07:16 PM
You need to download the Developer Conference (2005) material and review it.  It has all of your answers.
http://www.jasonnewell.net/Downloads/tabid/63/Default.aspx
Posted by: Jason Newell
Post date: 11/19/2008 7:53:15 PM
Hi,Jason,thank you very much!
Post date: 11/30/2008 7:04:11 PM
