How to create a thread feature?
I'm new in SE programming,and now i face a poblem.I need to create a thread feature on a cylinder,but when i use this API:
Set objThread = objModel.Threads.Add(Holedata:=objHoleData, _
                                                NumberOfCylinders:=1, _
                                                CylinderArray:=objCylinderArray, _
                                                CylinderEndArray:=objEndArray)
it always fails.Can anyone tell me where the mistake is ?
BTW,in "Programming with Solid Edge",it says CylinderEndArray is a array of faces,but in modeling,we select edge as the end of the cylinder.why?
Thanks!
Posted by: tiger wong
Post date: 3/2/2009 7:02:19 PM
RE: How to create a thread feature?
I have the same problem, i've to create a thread on a cylindrical protusion, I use that API, but i cannot understand what should I set as CylinderArray and CylinderEndarray!
Anyone can help me??
Thanks!
Alessandro
Posted by: Alessandro Morbidoni
Post date: 4/5/2011 2:18:49 AM
Same here. Looking for visual basic macro code.
Posted by: marek heero
Post date: 6/6/2011 5:18:54 AM
Re: How to create a thread feature?
Did you find a solution? I've got the same problem.
So many views and no one can give an example?
Greetings from Germany
Christian Kunkel
https://c-k-m.info
