How to disable automatic update of part/assembly when doing a View.Fit?
how to disable automatic update of part/assembly when doing a View.Fit?
Thanks in advance,
best regards
Massimo
c:\programming\solidedge st\custom\opensave,
use this code to update the part/assemblies.
'Force regeneration of triangle cash
objDoc.NewWindow
Set objNewWindow = objApp.ActiveWindow
objNewWindow.View.Fit
objNewWindow.Close
' Save the document
objDoc.Save
Posted by: Massimo Magris
Post date: 5/18/2009 9:37:58 PM
RE: How to disable automatic update of part/assembly when doing a View.Fit?
Massimo,
Could you elaborate exactly what you mean by "automatic update". What is it that is updating that you want to prevent?
Posted by: Jason Newell
Post date: 5/19/2009 12:05:12 PM
HI Jason,
maybe my misunderstanding.
Seems to me that the OpenSave (under SolidedgeST\CUstom)
for part and assemblies use th View.Fit as a way to force the update of the
document.
Is it possible?
If I'm wrong, which command is used to force th update of parts and assemblies by the OpenSave program?
This will help me clarify.
Thanks, regards
Massimo
Post date: 5/20/2009 2:29:51 AM
