How to disable command button and menu item
Hi all
How to disable (hazed) a commandbar button?
How to disable (hazed) a menu item?
I tried the following, but not works
commandbarbutton.disable=false
Posted by: jaya priyan
Post date: 1/20/2008 8:39:50 PM
RE: How to disable command button and menu item
Jaya,
If you're referring to an addin, you need to read "C:\Program Files\Solid Edge VXX\SDK\Samples\Addins\Doc\addin.doc".
Specifically, page 183, OnCommandUpdateUI.
Posted by: Jason Newell
Post date: 1/21/2008 6:04:02 AM
Thanks for your information Jason
This did the trick
Private Sub OnCommandUpdateUI(ByVal nCmdID As Long, lCmdFlags As Long, MenuItemText As String, nIDBitmap As Long)
lCmdFlags = seCmdActive_UseDotMark
nIDBitmap = 1
End Sub
Post date: 1/22/2008 10:07:35 PM
Can you give me an example?
I don't know how to use it.
Thanks.
Posted by: illuminiti illuminiti
Post date: 4/27/2011 11:18:58 PM
Technally speaking, set the value to zero. Add-in commands are assumed to be enabled (value on input should be 0x1).
For c++ you can do this:
*lCmdFlags &= ~ SolidEdgeConstants::seCmdActive_Enabled;
That would clear the bit that enables the command. Or just
*lCmdFlags = 0;
Posted by: R.D. Holland
Post date: 6/20/2011 6:26:01 AM
