How to discard a "Save" request?
I need to intercept and "discard"/skip a "save" request.
how to do this?
Thanks in advance,
best regards
Massimo
Posted by: Massimo Magris
Post date: 7/2/2009 2:59:46 AM
RE: How to discard a "Save" request?
Hi Massimo,
have a look at this (look at the last post):
http://www.jasonnewell.net/Forums/tabid/55/forumid/1/tpage/1/view/topic/postid/1354/Default.aspx#135...
Cheers
Calum
Posted by: Calum McLellan
Post date: 7/2/2009 3:12:45 AM
I think that you can use funtion of BeforeCommandRun, if the command id is the save command id, you can kill command.
Posted by: assassin 007
Post date: 7/6/2009 5:34:53 PM
