How to enter in "Draw in View" mode
I'm trying to enter in "Draw in View" mode after convert the DrawingView to 2d, but I can't find any procedure to achieve that.
I would be very grateful if anybody can help me.
Thanks a lot
My code:
Dim application As SolidEdgeFramework.Application = Nothing
            Dim documents As SolidEdgeFramework.Documents = Nothing
            Dim draftDocument As SolidEdgeDraft.DraftDocument = Nothing
            Dim sheet As SolidEdgeDraft.Sheet = Nothing
            Dim objModelLink As SolidEdgeDraft.ModelLink = Nothing
            Dim objDrawingView As SolidEdgeDraft.DrawingView = Nothing
            application = SolidEdgeUtils.Connect(True)
            application.Visible = True
            application.Activate()
            documents = application.Documents
            draftDocument = CType(documents.open("c:\temp\MACRO_ESCALA_1X1.dft"), SolidEdgeDraft.DraftDocument)
            sheet = draftDocument.ActiveSheet
            objModelLink = draftDocument.ModelLinks.Add("c:\temp\0509156.par")
            objDrawingView = sheet.DrawingViews.AddPartView(objModelLink, SolidEdgeDraft.ViewOrientationConstants.igFrontView,
                                                            1,
                                                            0.1,
                                                            0.1,
                                                            SolidEdgeDraft.PartDrawingViewTypeConstants.sePartDesignedView)
            objDrawingView.ModelMembers.Item(1).ShowHiddenEdges = False
            objDrawingView.ModelMembers.Item(1).ShowEdgesHiddenByOtherParts = False
            objDrawingView.Drop()
            'Enter "Draw in View" mode here...
            objDrawingView.?????
4 REPLIES 4
Re: How to enter in "Draw in View" mode
@Tiago_Bortolini,
@Tushar  has written a one-stop shop blog for you on just this topic
https://community.plm.automation.siemens.com/t5/Solid-Edge-Blog/All-about-Sheets-using-the-Solid-Edg...
Matt Johnson
SE2019 Pre-Production Testing
Teamcenter 10.1.7
Hi @Tiago_Bortolini
I had plans to include exactly this feature in the Sheets API article that @Johnson_BigMatt mentioned but decided to save it for the DrawingViews API article which will be published shortly.
Meanwhile, try accessing the Sheet property of the drawing view. All drawing view geometry objects (e.g. DVxxx objects) are contained by the drawing view sheet. Then use the Activate method on this sheet to enter the 'Draw in View' mode.
To exit the mode, Activate the Sheet that the drawing view itself lies in, which is a Working Sheet in the Draft Document object.
I am writing this from memory but at least 12 hrs away from going back and confirming it on a computer with Solid Edge. Please give it a try and let me know if it works.
~Tushar Suradkar
www.SurfAndCode.IN
www.CADVertex.com
@Johnson_BigMatt
@Tushar
Thanks a lot!!!! It worked perfectly.
'Draw in View mode
Dim seViewSheet As SolidEdgeDraft.Sheet = objDrawingView.Sheet
seViewSheet.Activate()
'Go back to the original sheet
sheet.Activate()
Oh, nice! I can see you declared the drawing view sheet variable as a SolidEdgeDraft.Sheet whereas it is mentioned simply as an Object in the API documentation.
Also knew you would want to exit the mode, so provided the extra tip to activate the working sheet - that's in the spirit of the Solid Edge Community!
