How to get ActiveFamilyMember Name of Part or Assembly
HI ,
1. How to get ActiveFamilyMember Name of a Part or an Assembly
opened in SolidEdge?
for assembly, I can getit from the window caption, but not for parts.
2. How to get LastSaved ActiveFamilyMember Name of a Part or an Assembly from revision manager or FileProperties?
With StructuredStorage, I can get info about Assemblies Family Members, but not wich one was active the last save.
Thanks in advance for any info,
Best regards
Massimo
Posted by: Massimo Magris
Post date: 3/13/2009 12:16:53 AM
RE: How to get ActiveFamilyMember Name of Part or Assembly
HI,
is not possible, SE Api does not have this functions.
Massimo
Post date: 3/16/2009 10:38:16 AM
there is a workaround for Part. It's not a beautiful code because I'm not a programmer but it works me fine.
doc = objapp.ActiveDocument
        families = doc.FamilyMembers
        pocet_variables = doc.FamilyMembers.FamilyVariableCount
        For counter2 = 1 To count_variables
            obj_variable(counter2 - 1) = doc.FamilyMembers.FamilyVariable(counter2)
            value_variable(counter2 - 1) = obj_variable(counter2-1).Value
        Next
        For counter2 = 1 To families.Count
            family = families.Item(counter2)
            family.Apply()
            identity = False
            For counter = 1 To count_variables
                IfNot (value_variable(counter - 1) = family.Variable(counter).Value) Then
                    counter = count_variables
                Else
                    identity = True
                EndIf
            Next
            If identity Then
                ' It's right member FOP
                searching_member = family.Name
                counter2 = families.Count
            EndIf
        Next
Vaclav
Posted by: Vaclav Blahnik
Post date: 4/28/2009 10:19:18 PM
