How to get Assembly from Weldment document
i want to get the assembly name from weldment document (.pwd) how do i get this. i am using vb.net and ST 4 .
Posted by: Yogesh Shinde
Post date: 6/18/2012 7:07:20 AM
Re: How to get Assembly from Weldment document
Use for this the WeldmentModel.
normaly is the count=1:
objDoc.WeldmentModels.item(1).FileName
objDoc is the opened weldement document
JR
Posted by: JR
Post date: 6/18/2012 8:15:34 AM
Thanks for the Reply i tried this it is working !!
Post date: 6/18/2012 9:03:46 AM
