How to get Features from synchronous document ?
Hi All
i want to read features from Synchronous document and how should i suppress or unsupress perticular feature from it
Posted by: Yogesh Shinde
Post date: 3/14/2012 1:41:53 AM
Re: How to get Features from synchronous document ?
Hi
I'm doing this myself at the moment. I'm using Visual Basic. What are you using?
Ian
Posted by: Ian Burrows
Post date: 5/4/2012 6:02:53 AM
Hi Yogesh
Here is a chunk of my code - You might find bit of it useful.
Also download SESpy.exe from JasonNewell
Imports SolidEdgeFramework
'Imports SolidEdgePart
Imports System.Runtime.InteropServices
Imports System
Imports System.Reflection
Imports System.Reflection.Emit
Imports System.Collections
Imports SolidEdgeConstants
Imports Microsoft.VisualBasic
Public Class Form1
Const NumNormalProps = 13
Const MECH_MATERIAL = 9
Const igFinite = 13
Public strChild(30) As String
Public strParent(30) As String
Public strPropVal(30) As String
Public strDate As String
Public strTitle As String
Public strSubject As String
Public strDrawn As String
Public strAppr As String
Public strDwgNo As String
Public strProject As String
Public strWeight As String
Public strMaterial As String
Public strPartID As String
Public strMatlID As String
Public strQTY As String
Public strUOM As String
Public objDocument As SolidEdgeFramework.SolidEdgeDocument = Nothing
Public objApplication As SolidEdgeFramework.Application = Nothing
Public objPart As SolidEdgePart.PartDocument = Nothing
Public objUOM As SolidEdgeFramework.UnitsOfMeasure = Nothing
Public objFeatureGroup As SolidEdgePart.FeatureGroup = Nothing 'Group
Public objFeatureGroups As SolidEdgePart.FeatureGroups = Nothing 'Group
Public objfeatures As SolidEdgePart.Features = Nothing 'Features
Public objfeature As SolidEdgeFrameworkSupport.FeatureControlFrame = Nothing
Public objAnyFeature As Object = Nothing
Public TotalFeatures, TotalHoles As Integer
Public objHoleDataCollection As SolidEdgePart.HoleDataCollection
Public objHoleData As SolidEdgePart.HoleData
Public objHoles As SolidEdgePart.Holes
Public objHoleProp As SolidEdgePart.Hole
Public CancelNow As Boolean
Private Declare Sub Sleep Lib "kernel32" (ByVal dwMilliseconds As Long)
Public Class PartData
Inherits [Object]
Private DataName As String = ""
Friend Members As New ArrayList()
Public Sub New(ByVal PartDataName As String)
Me.DataName = PartDataName
End Sub
Public Property PartDataName() As String
Get
Return Me.DataName
End Get
Set(ByVal Value As String)
Me.DataName = Value
End Set
End Property
Public ReadOnly Property MemberDetails() As ArrayList
Get
Return Me.Members
End Get
End Property
End Class 'End PartData class
' Create a new ArrayList to hold the Customer objects.
Private PartDataArray As New ArrayList()
Dim OStatus As Long
Dim ODensity As Double
Dim OAccuracy As Double
Dim OVolume As Double
Dim OArea As Double
Dim OMass As Double
Dim COG() As Double
Dim COV(10) As Double
Dim EngCOV(10) As Double
Dim GMI(0 To 15) As Double
Dim PMI(0 To 10) As Double
Dim PA(0 To 9) As Double
Dim PA2(0 To 9) As Double
Dim PA3(0 To 9) As Double
Dim ROG(10) As Double
Dim RAA As Double
Dim OUpdateStatus As Boolean
Dim OIsSick As Boolean
Private m_application As SolidEdgeFramework.Application
'Dim objDimension As SolidEdgeFrameworkSupport.Dimension
'Dim DimCount As Integer
Private Sub Form1_Load(ByVal sender As System.Object, _
ByVal e As System.EventArgs) Handles MyBase.Load
Try
' Connect to a running instance of Solid Edge
m_application = Marshal.GetActiveObject("SolidEdge.Application")
Catch ex As System.Runtime.InteropServices.COMException
MsgBox("SolidEdge not running")
End
Catch ex As Exception
MessageBox.Show(ex.Message, "Error")
Finally
End Try
End Sub
'methods/properties:
'AttachedPropertyTables, AttributeQuery,
'Constructions, CoordinateSystems, DocumentEvents, FamilyMembers,
'HighlightSets, Properties, PropertyTableDefinitions, RoutingSlip, SelectSet,
'Sketches, SummaryInfo, UnitsOfMeasure,
Private Sub Button1_Click(ByVal sender As System.Object, _
ByVal e As System.EventArgs) Handles Extract.Click
'Dim objDocument As SolidEdgeFramework.SolidEdgeDocument = Nothing
'Dim objApplication As SolidEdgeFramework.Application = Nothing
'Dim objPart As SolidEdgePart.PartDocument = Nothing
Dim objVariables As SolidEdgeFramework.Variables = Nothing
Dim objVariable As SolidEdgeFramework.variable = Nothing
Dim objVariableList As SolidEdgeFramework.VariableList = Nothing
Dim objProfileSets As SolidEdgePart.ProfileSets = Nothing
Dim objProfileSet As SolidEdgePart.ProfileSet = Nothing
Dim objProfiles As SolidEdgePart.Profiles = Nothing
Dim objProfile As SolidEdgePart.Profile = Nothing
Dim objDimensions As SolidEdgeFrameworkSupport.Dimensions = Nothing
Dim objDimension As SolidEdgeFrameworkSupport.Dimension = Nothing
Dim objModels As SolidEdgePart.Models = Nothing
Dim objModel As SolidEdgePart.Model = Nothing
Dim VarCount, DimCount, ProfCount, TotalSets, TotalProfs, i, ii As Integer
Dim TotalModels, ModelCount, NextNode, DOCnode, Addhere As Integer
Dim sName As String
Dim sFormula As String
Dim sValue As String
'Dim dValue, X, Y As Double
'Dim dHexSize As Double
Dim objHole As Object = Nothing
'SolidEdgeFrameworkSupport.DimensionStyle.SmartDepthHoleThru As String
'SolidEdgePart.HoleData.HoleType As SolidEdgePart.FeaturePropertyConstants
'SolidEdgePart.Hole.Depth As Double
Dim objFModel As SolidEdgePart.Model = Nothing
Dim objSelectSet As SolidEdgeFramework.SelectSet = Nothing
Dim objConstructions As SolidEdgePart.Constructions = Nothing
Dim objCopyConstructions As SolidEdgePart.CopyConstructions = Nothing
Dim objBooleanFeatures As SolidEdgePart.BooleanFeatures = Nothing
'The number of solid to do the boolean opertation
Dim NumberOfTools As Integer = 1
'A array which contains these solids
Dim Tools() As Object = Nothing ' {objConstructions.Item(1).Body}
'A member of the BooleanFeatureConstants constant set that specifies the type of Boolean operation to perform.
Dim Operation As SolidEdgePart.BooleanFeatureConstants = Nothing 'SolidEdgePart.BooleanFeatureConstants.seBooleanSubtract
Dim objPropCollection As New Microsoft.VisualBasic.Collection()
Dim objProp As SolidEdgePart.PropertyDefinition = Nothing
Dim objFaces As SolidEdgeGeometry.Faces = Nothing
Dim objGeometry As Object = Nothing
Dim objPropertySets As SolidEdgeFramework.PropertySets = Nothing
Dim objProperties As SolidEdgeFramework.Properties = Nothing
Dim objProperty As SolidEdgeFramework.Property = Nothing
Try
Variables.Items.Clear()
Dimensions.Items.Clear()
Features.Items.Clear()
' Get a reference to the active document
objDocument = m_application.ActiveDocument
objApplication = Marshal.GetActiveObject("SolidEdge.Application")
' Get a reference to the active document's unit of measure
objUOM = objDocument.UnitsOfMeasure
TextBox1.Text = "123.456"
TextBox3.Text = objDocument.FullName
objPart = objApplication.ActiveDocument
' Using Type property, determine document type
Select Case objDocument.Type
Case SolidEdgeFramework.DocumentTypeConstants.igAssemblyDocument
TextBox4.Text = "Assembly Document"
Case SolidEdgeFramework.DocumentTypeConstants.igDraftDocument
TextBox4.Text = "Draft Document"
Case SolidEdgeFramework.DocumentTypeConstants.igPartDocument
TextBox4.Text = "Part Document"
Case SolidEdgeFramework.DocumentTypeConstants.igSheetMetalDocument
TextBox4.Text = "SheetMetal Document"
Case SolidEdgeFramework.DocumentTypeConstants.igUnknownDocument
TextBox4.Text = "Unknown Document"
Case SolidEdgeFramework.DocumentTypeConstants.igWeldmentAssemblyDocument
Console.WriteLine("Weldment Assembly Document")
Case SolidEdgeFramework.DocumentTypeConstants.igWeldmentDocument
Console.WriteLine("Weldment Document")
End Select
' Attempt to parse the UOM input by user
'dHexSize = objUOM.ParseUnit(UnitTypeConstants.igUnitDistance, TextBox1.Text)
TextBox2.Text = objUOM.FormatUnit(SolidEdgeFramework.UnitTypeConstants.igUnitDistance, TextBox1.Text)
' Update the 2nd textbox with the parsed UOM
'TextBox2.Text = dHexSize.ToString()
'Add a variable
' objVariable = objVariables.Add("NewVar", "1.5")
'Change the formula of the variable to a function
' objVariable.Formula = Math.Sin(0.1).ToString()
'Change the name of the variable
' objVariable.Name = "NewName"
'Change the value of the variable. This will not change
'the value of the variable
' objVariable.Value = 123
'Variables.Items.Add(objVariables)
'Variables.Items.Add(objDocument.FullName)
' Use the Query method to list all all user-defined
' variables and user-named Dimension objects and
' display in the debug window
' objVariableList = objVariables.Query("*")
' For Each objVariable In objVariableList
'MsgBox(objVariable.Formula.ToString)
'Variables.Items.Add(objVariables.GetName(objVariable)) ' + " " + objVariables.GetFormula(objVariable))
' Next
' Make column headers.
' List the properties.
' Use the class you want to study instead of Form1.
Dim property_value As Object
Dim DOCproperties_info As PropertyInfo() = GetType(SolidEdgeFramework.SolidEdgeDocument).GetProperties()
' Suppress repainting the TreeView until all the objects have been created.
' TvwProperties.BeginUpdate()
' Clear the TreeView each time the method is called.
TvwProperties.Nodes.Clear()
TvwProperties.Nodes.Add("DOC " + objDocument.Name)
DOCnode = TvwProperties.GetNodeCount(False) - 1
For xxx As Integer = 0 To DOCproperties_info.Length - 1
With DOCproperties_info(xxx)
If .GetIndexParameters().Length = 0 Then
property_value = .GetValue(objDocument, Nothing)
TvwProperties.Nodes(NextNode).Nodes.Add("DOC1", "(Value) " + property_value.ToString, 1)
TvwProperties.Nodes(NextNode).Nodes(xxx).Nodes.Add("DOC2", " (Name) " + .Name, 2)
If property_value Is Nothing Then
TvwProperties.Nodes(NextNode).Nodes(xxx).Nodes(0).Nodes.Add("DOC4", "(Type) " + .PropertyType.ToString, 3)
Else
End If
Else
TvwProperties.Nodes(NextNode).Nodes.Add("DOC1", "<array>", 1)
TvwProperties.Nodes(NextNode).Nodes(xxx).Nodes.Add("DOC2", .Name, 2)
TvwProperties.Nodes(NextNode).Nodes(xxx).Nodes(0).Nodes.Add("DOC3", .PropertyType.ToString, 3)
End If
End With
Next xxx
NextNode = TvwProperties.GetNodeCount(False) - 1
TvwProperties.Nodes.Add("DOX " + objDocument.Name)
For ii = 1 To 1 'objDocument.Count
objPropertySets = objDocument.Properties
For iii = 1 To objDocument.Properties.count
'TvwProperties.Nodes(NextNode).Nodes.Add(objPropertySets.Item(iii).Name + " <<<<<< ")
'customerArray.Add(New Customer("Customer" + x.ToString()))
'PartDataArray.Add(New PartData("PartData" + objPropertySets.Item(iii).Name()))
TvwProperties.Nodes(DOCnode).Nodes.Add("DOX", objPropertySets.Item(iii).Name, 2)
'Addhere = PartData.Current
objProperties = objPropertySets.Item(iii)
For iiii = 1 To objProperties.Count
objProperty = objProperties.Item(iiii)
If objProperty.Value Is Nothing Then
sValue = objProperty.Name + " Nothing "
Else
sValue = objProperty.Name + " " + objProperty.Value.ToString
End If
TvwProperties.Nodes(DOCnode).Nodes(iii - 1).Nodes.Add("DOX", sValue, 3)
'PartDataArray.Item(Addhere).MemberDetails.Add(New sValue)
Next iiii
Next iii
Next ii
'TvwProperties.ExpandAll()
' Get a reference to the variables collection
objVariables = objPart.Variables
TvwProperties.Nodes.Add(New TreeNode("PART"))
Dim PartProperties_info As PropertyInfo() = GetType(SolidEdgePart.PartDocument).GetProperties()
For xxx As Integer = 0 To PartProperties_info.Length - 1
With PartProperties_info(xxx)
property_value = .GetValue(objPart, Nothing)
TvwProperties.Nodes(NextNode).Nodes.Add("PROP", .Name, 1)
Else
End If
Else
TvwProperties.Nodes(NextNode).Nodes.Add("PROP", "<array>" _
+ " (N) " + .Name _
+ " (T) " + .PropertyType.ToString, 1)
End If
Select Case .Name
Case "Models"
' Get a reference to the models collection
objModels = objPart.Models
TotalModels = objModels.Count
ModelCount = 1
TvwProperties.Nodes(NextNode).Nodes(0).Nodes.Add("MOD", "Model Data ", 1)
Select Case SelectedFeature.Checked
Case True
'ASSUME - only 1 model
objModel = objModels.Item(1)
Features.Items.Add(String.Format("Assumed Model Item = {0}", 1) + _
" DisplayName=" + objModel.DisplayName + _
" Hole Count =" + objModel.Holes.Count.ToString)
TvwProperties.Nodes(NextNode).Nodes(0).Nodes.Add("MOD1", String.Format("Assumed Model Item = {0}", 1), 2)
Features.Items.Add(" Number of shells ( in Models(i).Body )= " + objModel.Body.Shells.Count.ToString)
TvwProperties.Nodes(NextNode).Nodes(0).Nodes.Add("MOD1", " Number of shells ( in Models(i).Body )= " _
Post date: 5/7/2012 9:14:49 AM
You can pick features by identifying the ones you want by their properties which you can read
Post date: 5/7/2012 12:37:42 PM
I just encountered this the other day. When you get a Sync feature from a PartDocument collection like Rounds or Holes, you actually are getting a FaceSet object, which doesn't support the suppress property.
To distinguish the modeling mode, use the ModelingModeType property. If Hole features are added to the part in Ordered mode, then iterating over the Holes collection should give Hole objects instead of FaceSets.
Posted by: Jay Carlton
Post date: 5/17/2012 5:12:22 PM
