How to get Part features names in C++
HI,
I need to get the features of a Part model in c++.
I can get Features as a collection of IDispatch.
Than, how to "cast" to various features?
In visual basic its easy Object, but how to do the same in C++
Thanks in advance for any help.
Best Regards
Massimo
C++ test
    SolidEdgePart:Smiley TongueartDocumentPtr objDoc ;
    SolidEdgePart::ModelPtr objModel ;
    objDoc = objApp->Documents->Open("e:\\solidedge\\b.par") ;
    objModel = objDoc->Models->Item(1) ;
    SolidEdgePart::FeaturesPtr objFeatures ;
    objFeatures = objModel->Features ;
    long i ;
    IDispatch *f ;
    for (i=1;iCount;i++)
        f = objFeatures->Item(i) ;
VB Example that works
Private Sub Form_Load()
    Dim objApp As SolidEdgeFramework.Application
    Dim objDoc As SolidEdgePart.PartDocument
    Dim objModel As SolidEdgePart.Model
    Dim objFeats As SolidEdgePart.Features
    Const TESTFILE = "e:\solidedge\b.par"
    ' Report errors
    Const PI = 3.14159265358979
    ' Create/get the application with specific settings
    On Error Resume Next
    Set objApp = GetObject(, "SolidEdge.Application")
    If Err Then
        Err.Clear
        Set objApp = CreateObject("SolidEdge.Application")
        Set objDoc = objApp.Documents.Add("SolidEdge.PartDocument")
        objApp.Visible = True
    Else
        Set objDoc = objApp.ActiveDocument
    End If
    ' Close the part document
    Call objDoc.Close
    ' Open a Testcase
    Set objDoc = objApp.Documents.Open(FileName:=TESTFILE)
    ' Get the model object in the test case
    Set objModel = objDoc.Models(1)
    'Get the Features Object for the Model
    Set objFeats = objModel.Features
    Dim f As Object
    For i = 1 To objFeats.Count
        Set f = objFeats(i)
        Debug.Print i
        Debug.Print f.Name
        Debug.Print f.DisplayName
        Debug.Print f.EdgebarName
        Debug.Print f.SystemName
        Debug.Print f.Type ''Tipo di feature
        Debug.Print f.Suppress
    Next
    ' USER DISPLAY
    ' Release objects
    Set objApp = Nothing
    Set objDoc = Nothing
    Set objModel = Nothing
    Set objFeats = Nothing
End Sub
Posted by: Massimo Magris
Post date: 2/10/2009 5:24:21 AM
RE: How to get Part features names in C++
Massimo,
I don't have time right this second to give you a complete solution but here is what I've thrown together to give you an idea on how to do it.
  HRESULT hr = S_OK; IDispatch *pFeature; for (i=1;iCount;i++) { pFeature = objFeatures->Item(i) ; try { if( NULL != pFeature ) { DISPID rgDispId = 0; OLECHAR *szNames[] = {L"Name"}; hr = pFeature->GetIDsOfNames( IID_NULL, szNames, 1, LOCALE_USER_DEFAULT, &rgDispId ); if( SUCCEEDED(hr) ) { VARIANT varResult; VariantInit(&varResult); V_VT(&varResult) = VT_I4; DISPPARAMS disp = { NULL, NULL, 0, 0 }; hr = pFeature->Invoke( rgDispId, IID_NULL, LOCALE_USER_DEFAULT, DISPATCH_PROPERTYGET, &disp, &varResult, NULL, NULL ); if( SUCCEEDED(hr) ) { //varResult will contain the data } else { _com_issue_errorex(hr, pFeature, __uuidof(pFeature)); } } } else { hr = E_INVALIDARG; } } catch(_com_error &e) { hr = e.Error(); } }
Posted by: Jason Newell
Post date: 2/11/2009 6:59:22 AM
Jason,
thank you, its really a great help and starting point!!!
Massimo
Post date: 2/11/2009 10:54:59 AM
No doubt that late binding with COM objects in C++ sucks...
Post date: 2/11/2009 10:58:53 AM
