How to get Tube Bend Table with XYZ coordinates using Solid Edge API
I'ld like to display in a table on the draft sheet the bend table of a tube made with XpresRoute.
We manage to get Lenght, rotation, radius, angle informations like in the Solid Edge command, using :
ObjTube.BendTable(CutLength, NumBend, FeedBend, RotationAngle, BendRadius, ReverseBendOrder, OutputFile, BendAngle)
Now I want the result with a X, Y, Z, radius format like in the Solid Edge command,
Can you give me the method to convert the result to a X, Y, Z, radius format ?
Thanks Romuald
Romuald BERTIN
Re: How to get Tube Bend Table with XYZ coordinates using Solid Edge API
Did you find how to get the XYZ coordinates from the Tube Bend Table ?
I'm trying to get it but I can't find a good method...
