How to get Unique ID within an assembly?
I can't get any help with SDK.
I use C#.
3 REPLIES 3
Re: How to get Unique ID within an assembly?
What command is that in English? I can't translate the text. I also tried finding it by the icon but I'm not having any luck.
Jason Newell
Solutions Architect
www.jasonnewell.net
Same here.
The dialog with the unique ID column too is un-familiar, perhaps its a custom utility.
The version of SE is also not visible.
~Tushar
This is a Wire Harness command, you can find it in Tool and it's the report on wire.
Can find the UniqueID using SpySE, you may be more lucky.
Romuald BERTIN
