How to get a edge's endpoints coordinates in assembly document?
Jason, sorry to bother you. How to get a edge's endpoints coordinates in assembly document? I tried with the function of Vertex.GetPointData(ref Array), but the the coordinates is in part document. Could you give me a example? Thanks!
Posted by: assassin 007
Post date: 6/18/2009 7:29:59 AM
RE: How to get a edge's endpoints coordinates in assembly document?
I'm including an example for you (VBNet)
The example works with a part placed directly under the main ASM. If the part is placed in a subassembly or below, then it's a little more complicated.
I hope this helps,
Julian
Posted by: Julian Guillo
Post date: 6/18/2009 11:53:45 PM
Hi, Julian, thanks! I have another questions, could you help me to analyze the following codes in C#?
faces=Array.CreateInstance(typeof(SolidEdgeGeometry.Face),2);
refPrimface = asmdoc.CreateReference(primoccur, (object)face) as SolidEdgeFramework.Reference;
edge.GetFaces(out facenumber, ref faces);
for (int i = 0; i
slaveface = faces.GetValue(i) as SolidEdgeGeometry.Face;
if (slaveface != face)
break;
refSlaveface = asmdoc.CreateReference(primoccur, (object)slaveface) as SolidEdgeFramework.Reference;
refPlane = asmdoc.AsmRefPlanes.AddParallelByDistance(refPrimface,
0,
SolidEdgeConstants.ReferenceElementConstants.igNormalSide,
refSlaveface,
SolidEdgeConstants.ReferenceElementConstants.igPivotStart,
Missing.Value);
holedata=asmdoc.HoleDataCollection.Add(SolidEdgePart.FeaturePropertyConstants.igRegularHole,
ecc.GetD1()/1000.0,Missing.Value,Missing.Value,Missing.Value,
Missing.Value,Missing.Value,Missing.Value,Missing.Value,
Missing.Value,Missing.Value,Missing.Value);
layout = asmdoc.Layouts.Add(refPlane, null,out layoutstatus);
profile = layout.Profile as SolidEdgePart.Profile;
profile.Convert3DCoordinate((double)newstartpt.GetValue(0), (double)newstartpt.GetValue(1), (double)newstartpt.GetValue(2),
out x2d, out y2d);
profile.Convert3DCoordinate((double)newendpt.GetValue(0), (double)newendpt.GetValue(1), (double)newendpt.GetValue(2),
out x2ds, out y2ds);
if (x2d
x = x2d*1000; y = y2d*1000;
else
x = x2ds*1000; y = y2ds*1000;
profiles = new List();
y += ecc.GetH2();
layouts = new List();
for (int i = 0; i
x += holespacelist.GetSpacevalue();
if (holespacelist.GetNextHoleType() == 1)
profile.Holes2d.Add(x/1000,y/1000);
profiles.Add(profile);
aProfiles = Array.CreateInstance(typeof(SolidEdgePart.Profile), profiles.Count);
for (int i = 0; i
aProfiles.SetValue(profiles, i);
aParts = Array.CreateInstance(typeof(SolidEdgeAssembly.Occurrence), 1);
aParts.SetValue(primoccur, 0);
extendside=SolidEdgePart.FeaturePropertyConstants.igLeft;
holedepth=ecc.GetH1()/1000;
keypointflag = SolidEdgePart.KeyPointExtentConstants.igInteriorTangentNormal;
asmfeatures = asmdoc.AssemblyFeatures;
Array tempProfile = Array.CreateInstance(typeof(SolidEdgePart.Profile), 1);
tempProfile.SetValue(aProfiles.GetValue(0), 0);
asmholes = asmfeatures.AssemblyFeaturesHoles;
asmhole = asmholes.Add((uint)aParts.Length, ref aParts,
//(uint)tempProfile.Length,ref tempProfile
(uint)aProfiles.Length, ref aProfiles,
ref extendside,
holedata,
SolidEdgePart.FeaturePropertyConstants.igFinite,
ref holedepth,
null, null, null, ref keypointflag);
Post date: 6/20/2009 6:53:43 AM
If the aProfiles.Length>1, the assemblyfeaturehole will be not created correctly. There should be a excalmatory mark(!) before the feature. And the Feature will be ok after I modified it, I do nothing just enter the hole's sketch and return, it will be ok. How to modify my codes? Maybe you can give me an idea?
Post date: 6/20/2009 7:02:08 AM
,Hi, All, anybody can help me ?
Post date: 6/22/2009 2:19:35 AM
