Reply
Solved! Go to solution
How to get area of a face?
Could someone please post an example of how to get the area of a face on a model? I have a flat pattern export macro and I need to find the area of the flat face/faces resulting from the flattened model. This would be the actual area of the flattened model, not simply the area of the XY extents- so I can't just use the X and Y cut sizes.
Thanks.
-Dylan Gondyke
Solution
Solution
Accepted by topic author Chally72
‎08-26-2015 04:32 AM
The Area property of the Face object is what you are look...
The Area property of the Face object is what you are looking for...
Re: The Area property of the Face object is what you are look...
I found some excellent examples in the SDK help that worked fine once I fixed problems with my declarations Smiley Happy
-Dylan Gondyke
